Belly Tuck - JeepForum.com
post #1 of 9 Old 08-22-2012, 05:28 PM Thread Starter
mrmark
Belly Tuck
I have an 8.8 and an NP231 with SYE and want to know if I can remove the drop spacers on the transfer case and tuck it back to the stock location.
Pictures will be put in the next post as they are on my phone not computer. SORRY
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #2 of 9 Old 08-22-2012, 05:29 PM Thread Starter
mrmark
mrmark is offline
post #3 of 9 Old 08-22-2012, 05:42 PM
G30SFF250
I plan to do my tummy tuck at the same time that I do my rear axle swap. Set the pinion angle once.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #4 of 9 Old 08-22-2012, 05:46 PM Thread Starter
mrmark
I understand that, but I have the 8.8 set now (and it was set up with the spacers in) and want to know if I can pull the spacers and tuck it now or if it will be too much of an angle
mrmark is offline
post #5 of 9 Old 08-22-2012, 08:56 PM
zte87
GIVE IT THE ONION
zte87's Avatar
It's hard to say, it not hard to take the spacers out if it throw is off to bad you can fix it with a small degree shim. When I did my 8.8 I made sure my tc drop was tossed So I would't have to worry about it. I know that does't help you but just saying.........
zte87 is offline
post #6 of 9 Old 08-22-2012, 09:07 PM
ThomasYJ
To go along with what zte87 said, best way to find out, considering how easy it is, is to just pull the skid spacers and take her for a shake down run. Just take it easy and you'll find out in short order whether you've got vibes or not.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #7 of 9 Old 08-22-2012, 10:02 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
So you're going back to stock and not doing a tummy tuck? I would take it one step further and get the brown dog motor mount lift and a teraflex belly up pan and go all out while you're in there.
Then again, y'all don't seem to have too many rocks in Florida that aren't used by landscaping crews...
Luck Favours The Prepared
Anticanman is offline
post #8 of 9 Old 08-23-2012, 12:04 PM Thread Starter
mrmark
I was just going to remove the spacers and gain that much height back. Not looking to change anything else at this time. The main goal right now is to get it back up and running and this is just a matter of putting it back together without the spacers if it can be done without having too much angle.
I guess I'll have to do what ThomasYJ suggested, I was trying to get an answer before and not have to go back and undo the change if it doesn't work.
mrmark is offline
post #9 of 9 Old 08-23-2012, 03:08 PM
ThomasYJ
I tried asking the same question you did a few months ago and its just one of those things that's hard to say.. no definitive answer because everyone's Jeep has it's quirks as I'm sure you're aware. Antican could have it one way, yours another way, and mine some Frankenstein combo of the two, ya know?
hope it works for you though
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
Belly Up - Tummy Tuck bradentaala TJ Wrangler Technical Forum 13 03-19-2010 08:33 AM
Tummy tuck, belly up machinehead131 YJ Wrangler Technical Forum 30 06-08-2009 01:25 PM
Tummy Tuck v Belly Up outlawjosywales TJ Wrangler Technical Forum 20 03-09-2009 11:46 AM
tummy tuck/belly up questions pwoens YJ Wrangler Technical Forum 18 12-06-2007 03:48 PM
best belly up/tummy tuck JeepMKcomin TJ Wrangler Technical Forum 13 05-08-2007 03:50 PM
