Bellhousing - JeepForum.com
post #1 of 2 Old 09-15-2010, 05:09 AM Thread Starter
jleal_21
Bellhousing
I have a bellhousing from a 4 cyl 98 dodge Dakota, will this housing work for a ax-15 swap?
jleal_21 is offline
post #2 of 2 Old 09-15-2010, 07:19 AM
5-90
5-90's Avatar
1988 XJ Cherokee
No. I don't what transmission it came off of (I don't think the AX-15 was used behind the 4-150 in the Dakota - but that's more a matter of spotty recall than anything else. I could be wrong about that...) but the bellhousing pattern on the 4-150 is the same as the GM 60-degree V6, which is not the same as the AMC I6/V8 pattern on the back of the 6-242.
The AX-15 was used in the XJ/MJ/YJ (internal slave) behind the 6-242 and 6-258 1988.5-1993, and the XJ/YJ/TJ/ZJ behind the 6-242 (external slave) in 1993 (ZJ,) 1994-1995 (YJ,) 1997-1998 (TJ,) and 1994-1999 (XJ.) The NV3550 (external slave only) was used 2000-2001 XJ w/6-242 and 1999-2005 or so TJ w/6-242. The NV3550 uses the same bellhousing as the AX-15e, but you'll have to get an AX-15e front bearing retainer to convert he earlier AX-15i to use the external slave (but that's perfectly doable.) The AX-15 and NV3550 can also be found in the V6-equipped Dakota (although the bellhousing will be wrong) of similar vintage, as well as some later LA318-equipped Dakotas (for the NV3550.)
The 2005-2006 TJ w/6-242 also used the NSG370 with the AMC bellhousing pattern, so that's another possibility...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
BellHousing ColoradoCole TJ Wrangler Technical Forum 2 08-01-2010 11:20 PM
Bellhousing? cjwdzr YJ Wrangler Technical Forum 2 02-25-2010 11:01 AM
Need a little bellhousing help please... 1987jeepyj YJ Wrangler Technical Forum 5 01-23-2009 12:18 PM
bellhousing Tri_X_Troll TJ Wrangler Technical Forum 1 01-11-2006 06:34 PM
Do the AX-15 and BA-10/5 use the same bellhousing? Richmond88yj YJ Wrangler Technical Forum 6 10-18-2005 10:56 PM
