Bell-Housing to Block, Bolt Size, (thread size)?? - JeepForum.com
post #1 of 4 Old 07-29-2012, 07:25 PM Thread Starter
az_zoner
I bought a new/rebuilt engine today for my 91 YJ. 2.5l. I'm trying to get it on my engine stand but I can't find the size of the bolts (thread size) so I can bolt it up. A 1/2-13 doesn't seem to fit. Anyone know? is it 12mm?
thanks for any help.
Craig
az_zoner is offline
post #2 of 4 Old 07-30-2012, 11:19 AM Thread Starter
az_zoner
To answer my own question I kept looking and found this web site. Very Good info on bolt specs;
http://www.torkspec.com/torkspecmm.aspx?KI=278
cb
az_zoner is offline
post #3 of 4 Old 07-30-2012, 11:48 AM
pete1991YJ
Mine was 7/16-14
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 4 Old 08-06-2012, 09:14 PM Thread Starter
az_zoner
Ok, For you that are using 7/16-14, I'd be carfull. the thread is actually 12X1.75 metric. I finally got a thread gage from work and the 12mm fit correctly. Or that is what my 94 yj 2.5 engine has.
Craig
az_zoner is offline
Bolt Size? .312-18x.238 or .970 (Thermostat Housing) cdrymalla TJ Wrangler Technical Forum 9 05-12-2015 03:32 PM
4.0L Transmission to Block bolt size Delta347 YJ Wrangler Technical Forum 6 07-18-2011 11:40 PM
Bell Housing Bolt sgort2 TJ Wrangler Technical Forum 9 06-25-2011 07:27 PM
Bolt hole size in bottom of block for skid plate Dutra177 TJ Wrangler Technical Forum 9 05-15-2011 01:28 PM
Bellhousing to Block bolt type/size viper719 YJ Wrangler Technical Forum 5 05-17-2010 10:42 AM
