Beginners Shaft - JeepForum.com
post #1 of 5 Old 12-04-2010, 08:53 AM Thread Starter
ekenfecker
ekenfecker's Avatar
Beginners Shaft
My U-joints are shot on the steering shaft and I thought I should replace the lower shaft bearing at the same time. I'm unsure if a new shaft comes with the bearing. Do I need to order shaft and bearing rebuild kit or just get shafted?
If it had a hamburger on it, I bet you could find it.
1995 I6 YJ
ekenfecker is offline
post #2 of 5 Old 12-04-2010, 09:25 AM
jeepnbrett
8051150 - Steering Shaft Assembly For <b>1987-95 Jeep Wrangler</b> | Discount Jeep Parts
Just did my steering shaft. The bearing needs to ordered seperate. There are several options as far as places to purchace the shaft. This one is a stock replacement. There are also heavy duty options available if you feel the need.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #3 of 5 Old 12-04-2010, 11:18 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Helpful link: http://www.jeepforum.com/forum/f12/l...t-pics-741968/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 5 Old 12-04-2010, 07:11 PM Thread Starter
ekenfecker
ekenfecker's Avatar
Thanks.
Free the Hikers Home &#187; freethehikers.org
1995 I6 YJ
post #5 of 5 Old 12-06-2010, 06:53 PM
HAVASUJEEPERJR
Does anyone know how to get the steering shaft off the YJ? I took the bolts out and cant seem to get it off. Is there a special handshake I need to do with it before it comes off? I'm replacing it and really dont care if i cut it, but I want to make sure that the new one goes on smoothly! Please help if you can....
1990 YJ
4" lift
Fuel injection
33" Goodyear MTR's
Mile Marker 8000 with synthetic rope
HELLA 4000 compact lights
HAVASUJEEPERJR is offline
Manifold for beginners TheBeast TJ Wrangler Technical Forum 46 08-08-2011 05:45 PM
Non-Rubicon driveshaft U-joints. Front shaft and rear shaft use the same? BWFBezerk TJ Wrangler Technical Forum 8 01-15-2010 06:23 AM
Does this sound like an alright beginners set up? TOLjeep TJ Wrangler Technical Forum 17 08-28-2008 06:28 AM
No front d-shaft-no problem...w/ d-shaft-death wobble and can't get to 50mph...help gadawgz71 TJ Wrangler Technical Forum 5 08-06-2008 03:12 PM
Beginners cost guide to modding sromain JK Wrangler Technical Forum 15 07-21-2008 10:24 AM
