Before I cut it out - JeepForum.com
post #1 of 3 Old 01-23-2013, 06:37 PM Thread Starter
sirhc76
Before I cut it out
Almost done with my two year project. I did a rear stretch and welded in a new rear cross member using 3/16x 2x4 rectangle tubing as others have done. I did the old heat and bend on the tank to clear my 8.8 but I need just a few more inches. Any negatives to cutting out the cross brace that the front of the tank mounts to and either raising it up or replacing it with a 2x2 section of square tubing? I have a 1 inch body lift so I have room to move the tub mounts up.
Thanks,
sirhc76 is offline
post #2 of 3 Old 01-23-2013, 06:51 PM
gunshw301
Not sure if this will help give the room your looking for, but it might be an option.
http://www.jeepforum.com/forum/f12/t...-tank-1407078/
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 3 Old 01-23-2013, 11:48 PM
fratis
fratis's Avatar
dont think you will have a problem. i did the heat and dimple thing years ago and it leaked a bit recently from the dimple itself. strange thing it only leaked for a day.
-insert meaningless out-of-place political diatribe-
fratis is offline
