beefing up a np231 - JeepForum.com
post #1 of 3 Old 08-09-2010, 06:19 PM Thread Starter
tyrap26
beefing up a np231
i came across a few guys beefing up there 231,
im SYE less right now and was planning on getting one for my next upgrade, i was seeing since the case will be open, should i try swapping a few parts? ive seen the 6 planetary, wider chain......etc. is it worth doing? any of you done it? let me know what you think.. tks
tyrap26 is offline
post #2 of 3 Old 08-09-2010, 06:20 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would do the "true neutral" TJ style shift selector plate upgrade.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 08-09-2010, 07:06 PM
moonshinefuel
The transfer case is one of those things I am looking at as well. You really have to factor how much money it is going to cost to achieve what you want to accomplish. So, how much is it going to cost. The 231 is a good case, but if I think I am going to approach the 1000 dollar mark, or near it, I am going to go in a different direction other than the 231 most likely. For me it comes down to money, where is my limit on how much I am going to put into my T-case, before I just opt out and go with say a NV241OR. I had a line on a new tera low T-case kit for 500 dollars, it was new, they go for twice that new, and I had the money, but still did not buy it. Because I figure, I'd still need the sye, that's 300 plus dollars more for the one I want..over 800 bucks there. I've seen 241OR t-cases for 800 bucks, I'd rather have that. That's how I look at it personally, but really it does not mean it is the best alternative for you.
moonshinefuel is offline
beefing up a d30 CreepyCrawler95 YJ Wrangler Technical Forum 11 03-24-2009 08:47 PM
beefing up my D35 mookarma TJ Wrangler Technical Forum 7 02-08-2005 03:11 PM
Beefing up a AX5 Six Shooter YJ Wrangler Technical Forum 6 12-30-2004 07:46 AM
beefing up bpavlov YJ Wrangler Technical Forum 5 07-12-2003 12:30 AM
Beefing up a 4 litre Sidewalkman YJ Wrangler Technical Forum 8 07-09-2003 11:26 PM
