Quantcast bedliner done - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > bedliner done
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 10-24-2006, 07:38 PM   #1
bobbert350
bedliner done
here are the pics i dont no if u have to subscribe to see them but its free so i used this site
http://s131.photobucket.com/albums/p300/bobbert350/?action=view&current=DSCN1406.jpg&refPage=&imgAnch =imgAnch1
http://s131.photobucket.com/albums/p300/bobbert350/?action=view&current=DSCN1407.jpg&refPage=&imgAnch =imgAnch4
http://s131.photobucket.com/albums/p300/bobbert350/?action=view&current=DSCN1408.jpg&refPage=&imgAnch =imgAnch5
b4 the bedliner (while sanding)
http://s131.photobucket.com/albums/p300/bobbert350/?action=view&current=DSCN1403.jpg&refPage=&imgAnch =imgAnch2
http://s131.photobucket.com/albums/p300/bobbert350/?action=view&current=DSCN1402.jpg&refPage=&imgAnch =imgAnch3
bobbert350 is offline   Reply With Quote
Old 10-24-2006, 08:01 PM   #2
alw041
Looks awesome!
Is that a Herculine DIY kit?
If so....how hard was it, and any pointers?
alw041 is offline   Reply With Quote
Old 10-24-2006, 08:13 PM   #3
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
next time you post pics from photobucket copy and paste from the index page... under each pic there will be three different url's to choose from. copy and paste the one with the IMG tag....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 10-24-2006, 08:15 PM   #4
bobbert350
its durbac bedliner the reason i got it is the texture isint as much as on herculine...i did it myself the pointers i have is that.
1. buy more than one brush to put the paint on do not buy sponge brushes buy the cheap ones
2. its all in the prep work so get all the prep work done use a palm sander and make sure everything is sanded well either by hand our with a tool
3.wash out the jeep then use xyleen solution when the inside is dry. i went over the whole thing with a rag then with another rag i did it again
4.mix well
5. use a paint tray and mix before u brush every time the bumpy partices will settle at the bottom
6.if using the paint brush dab it on do not brush.. an example would be making dots on a pice of paper with a pencil all u do is poke.
7.DONT PAINT YOURSELF INTO A CORNER!!
8.either clean off your shoes b4 getting into you jeep or go with socks because u will get dirt in there
9.make sure its well venelated expecially with the xyleen solution.
10. when done you are done using the roller between coats put it in xyleen solution to clean it off so it does not get hard do the same to the brush.(do this outside the xyleen solution is strong and will make u dizzy i learned from expierence)
11. do not clean out the paint tray its just gonna get tossed anyway so get a cheap one its makes a bigger mess than its worth.
12.if i didnt say this already use a paint tray its a lot better than dipping in the bucket and it keeps it more consistant
Old 10-24-2006, 08:17 PM   #5
bobbert350
this is just a test i never copied and pasted pic
javascript:window.open('http://i131.photobucket.com/albums/p300/bobbert350/DSCN1406.jpg','FullView','width=700,height=500,res izable,scrollbars,location'); void('');
Old 10-24-2006, 08:23 PM   #6
bobbert350
how do u post pictures?? i dont get what u said big and broke
Old 10-24-2006, 08:25 PM   #7
bobbert350
i think i got it now
Old 10-24-2006, 08:33 PM   #8
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
you've got it
Old 10-24-2006, 08:50 PM   #9
alw041
What do you mean by: that it doesn't have has much texture as herculiner?
Also is herculiner a flat black or a shiny black like yours?
Where did you buy the durbac bedliner?
Old 10-24-2006, 09:58 PM   #10
bobbert350
when i help my friend do his truck bed the herculiner the bumps are alot bigger. i think it is as shiny mine will dull out a little bit i took the pics when it was still wett..those tips i posted most of them are from expierence well amost all so it will help out alot..if u need help with it just p/m or something..i used the durbac bedliner i got away with a little over 1/2 gallon and i did 2 coats.. i think im gonna do another one again...but this weekend
Old 10-24-2006, 11:09 PM   #11
alw041
I am thinking about the herculiner....Any cons about it? also how much bigger are the bumps?
Old 10-24-2006, 11:56 PM   #12
jeep350chevy
1987 YJ Wrangler
nice looks good, looks just like my herc job i just did, justin
jeep350chevy is offline   Reply With Quote
Old 10-25-2006, 12:09 AM   #13
flame0086
I don't know will help out, but this is some pics of my Herculined tub.
Most important step, do not corner yourself. It is a really esay task. I got the Herc kit for $80. Follow the instructions. Prep, clean, xylone, Herc.
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 10-25-2006, 07:21 AM   #14
bobbert350
yea herculiner is not much differnt the only thing is that i found is the bumps were bigger..or they clumped up more...thats the only difference that i found..also herc may be a tiny bit less shiny which could be good or bad depending on which one u like
Glock Forum
