Beating a Dead Horse - Page 2 - JeepForum.com
post #16 of 19 Old 12-24-2013, 01:14 PM
dancytron
Originally Posted by Kingston View Post
ok had to call re quick to a buddy to go look at something.....in the picture theres, whatever it is circled in red, that is were the second line from the Evap can is leading to....but as u see in the pic the other end is just open with no line...WTH is this? whats it for and do i need it? if not can i just unhook that line goin from the can to it or do i need to T this is some place.
That is the Decel Valve. http://home.sprynet.com/~dale02/decel.htm Mine leaked, so I removed it.
FWIW, the EGR and Charcoal canister do not hurt performance or fuel economy in any way. The only benefit of removing them is to pollute more.
I vaguely remember that Maryland is like we are here in Missouri, that they check for the EGR valve and Charcoal Canister as a part of the safety inspection. I would double check that.
dancytron is online now
post #17 of 19 Old 12-24-2013, 07:24 PM Thread Starter
Kingston
1987 YJ Wrangler
The vacuum advance for the distributor is supposed to be on a ported line. Quick way to test the line its on...start the motor, take the vac line off going to the dist., if the tube that you took the line off of has any vac, then its the wrong tube.
Vacuum advance works to advance timing when you are on the throttle, NOT when you are idling. If the motor is at an idle, the line going to the dist wont have any vacuum on it.
Could that be why im not idleing? And have to feather the gas to stay running
1987 YJ Wrangler 4.2ltr 5 speed 4" rough country lift with 31x10.50 tires
MOLAN LABE
KCCO
Kingston is offline
post #18 of 19 Old 12-25-2013, 07:40 PM
swatson454
1983 CJ7
Most of us on the CJ board run manifold vacuum for its many benefits over ported vacuum. I'd keep it on manifold vacuum, especially with a smaller 32/36.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #19 of 19 Old 12-26-2013, 04:42 PM
Old4X
1990 CJ7
Shawn
Manifold vac is better for your engine and drivability
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
