Beadlocks--Homemade VS Store Bought - JeepForum.com
post #1 of 8 Old 08-18-2011, 09:14 PM Thread Starter
Fireman4X4
Ok folks, I have a question: is it cheaper/easier/more functional/aesthetically pleasing to either use a DIY beadlock kit, store bought set-up, or all homebrew stuff?
I would prefer to either use a DIY kit or find someone with a CNC and bribe them with beer just for the simple fact that it would be "homemade". However, I only have minimal welding skills and even fewer funds (like most of us). For those of you with beadlocks, what is your opinion? It is not an immediate project, but something that has slowly been moving up on my project list. I want to make sure I research before I even think about starting.
So, thanks in advance for your help!
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
Colorado Jeep Club Member #252
1994 YJ with lots of fun stuff
2003 KJ Bone stock piece of junk[/COLOR][/CENTER]
Fireman4X4 is offline
post #2 of 8 Old 08-18-2011, 09:49 PM
adamsclarke
If you have minimal welding skills, your DIY's will leak. If you already have steel wheels, DIY is more cost effective, but if you don't...then just get a set of allieds.
adamsclarke is offline
post #3 of 8 Old 08-18-2011, 09:51 PM
timatoe
timatoe's Avatar
I wouldn't suggest welding them yourself if you have minimal skill, however you could likely find a local shop to weld them up for not much money.
timatoe is online now
post #4 of 8 Old 08-18-2011, 10:09 PM
92 Green YJ
92 Green YJ's Avatar
I agree with not welding them yourself if you are not that good at welding. Even with decent skills it can be difficult to get an air tight weld bead. I actually ordered an extra ring to do my spare (which I did first) and sure enough, it leaked. took some time to find and fill the little pinholes, but the other four worked perfectly. Got my kit from great lakes offroad.
here is an article I did on installing my DIY weld on beadlocks
http://jeepaholics.com/support/Topic582757.aspx
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 8 Old 08-18-2011, 10:23 PM Thread Starter
Fireman4X4
I have been looking all over this tiny town (pop. 3500) for someone who can do larger, better weld jobs for me. Have yet to find one Had a buddy who had his own welding business, but sadly he moved to New Mexico. Guess I could head down the mountain to Denver. But like I said, no rush on this so its no big worry. Yet!
92, nice article. Thanks a lot!
post #6 of 8 Old 08-18-2011, 10:29 PM
92 Green YJ
my pleasure. took me about a week to do it all but i took it slow and did one wheel per day. took a lot of muscle to remove the tires from the wheels, then clean the paint off the weld area, weld, let cool, paint, muscle tires back onto rims, and took forever to tighten and torque 32 bolts per wheel.
My
post #7 of 8 Old 08-19-2011, 12:57 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you tried looking in the for sale forum here or on various forums for a set of used beadlocks?
It took me a few months before I finally found the exact wheels I wanted, but it was worth the wait and the price was excellent too.
I needed a set of 17x8's with a WBP of 8x6.5" and 5.25" back spacing due to the high steer arms I'm running.
These are the Walker Evans I found/picked up:
Joe Dillard is offline
post #8 of 8 Old 08-19-2011, 03:08 AM
chris_ce
The price it cost in steel is about them same as you can buy a DIY kit. It's a great opportunity to get better at welding. Don't worry to much about the pin holes try to get them all but if you don't it's not the end of the world. Run a bead of RTV around the tire before you clamp it down and the pin holes are taken care of.
chris_ce is offline
How low psi can i run without beadlocks RakHard-187 TJ Wrangler Technical Forum 19 07-02-2009 11:45 AM
Beadlocks dencor Wrangler General Discussion 2 09-13-2008 04:38 PM
Brick and mortar store versus Internet store DonziJeep Wrangler General Discussion 2 06-18-2008 06:00 PM
beadlocks xj 98/yj 94 YJ Wrangler Technical Forum 8 05-01-2007 01:58 AM
Store Bought JuiceBox mitchj01 YJ Wrangler Technical Forum 4 08-17-2002 07:21 AM
