BDS 3.5" Kit coming Friday.... What else do i need? - JeepForum.com
post #1 of 18 Old 07-13-2011, 10:23 PM Thread Starter
jayvando707
got a BDS 3.5" kit coming Friday for my YJ... Its coming with the BDS 1" boomerang shackles.... so technically its a 4.5" kit...
other than the obviousSYE and Shaft WHAT ELSE SHOULD I LOOK INTO GETTING?
Are the supplied BDS shocks any good? i also bought extended brakes lines...
Anyone running this setup? 3.5" SUA 1'' SL?
Thanks!
It is better to be tried by 12 than to be carried out by 6....
jayvando707 is offline
post #2 of 18 Old 07-14-2011, 05:19 AM
grandboost98
if you plan on cutting the old bolts out, buy new, grade 8 bolts. the shocks seem to be kind of cheap, just plan ol white ones. and if your hard brake lines are in as bad of shape as mine were, plan on running new hard lines
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 18 Old 07-14-2011, 06:09 AM
Louie4
See if you can get a buddy and tempt them with pizza and a 6 pack (if that's your/their preference). Might not hurt to get some PB Blaster.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 18 Old 07-14-2011, 06:15 AM
grandboost98
x2 also a bunch of cutting wheels or sawzall blades, cutting wheels are way faster but not everyone likes to use them. PB anything you dont plan on cutting off starting now and everyday up to the install
post #5 of 18 Old 07-14-2011, 07:46 AM
Mameluke
you will cut off four times as many bolts as you set out intending to. rear shackles are a ***** because of the gas tank, so you will have to cut those. the rear bolts for the front springs were the worst of the whole project. took forever to get them out. had to grind down the whole bolt head and beat the whole thing with a hammer. buy alot of beer and copenhagen.
i run that basic set up, but i havent done SYE yet...soon enough. i have no issues with the shocks other than what grandboost said, they are just plain white and look sort of cheap. but i dont really care about that too much.
Mameluke is offline
post #6 of 18 Old 07-14-2011, 08:00 AM
grandboost98
i think that the shocks are contributing to my rough ride aswell as limiting my flex. usually when you see plain white shocks that mean theyre just average shocks that most companys will use. if i could do it over again i would have pieced my kit together and saved some money
post #7 of 18 Old 07-14-2011, 08:15 AM
jaycal3
I just went 3.5" BDS and 1" Prothane BL... Gave up on trying to install myself and left it to the pro's due to the nutserts all spinning on me from the old mounts and BL... I dont have welding skills so it was well worth having it done correctly the first time. Love the lift! No SYE yet and no vibration at all. I got the blue shock boots to dress up the plain white shocks, but I dont think it would have bothered me either way.
Here she is now on the 3.5" BDS and 1" BL:
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #8 of 18 Old 07-14-2011, 09:43 AM
YJames90
YJames90's Avatar
I dont think they come with the poly bushings on each end. You may have to order them seperatly
My 2.5 to 4.3 swap thread
YJames90 is offline
post #9 of 18 Old 07-14-2011, 03:07 PM
95wrangler4life
no SYE and no vibs but you do have a transfer case drop installed....
however i love the look, i take it those are 33's? I am looking at dropping a inch of lift of my heep and going to be ordering BDS springs for it, just haven't decided if I am ordering 2" or 3.5". not gonna hi-jack this thread gonna start one in a minute related to this!
i still want to start over on my exterior and get the dark blue and the tan interior, but i spend money on other dumb crap lol
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #10 of 18 Old 07-14-2011, 03:50 PM
jaycal3
Yes I have a transfer case drop... he was asking for anything else he may need outside the kit and this comes with the kit. And yup, 33's.
Will wait for your thread
KCCO
jaycal3 is offline
post #11 of 18 Old 07-15-2011, 11:40 PM Thread Starter
jayvando707
just installed the lift.... JESUS! this thing is way higher than 3.5" + 1" booms!!!! No vibes! only on deceleration a bit.... threw some 33's on 17's on there while i buy 33's for my 15" rims.... wow! the ride is SO much better than my stock saggy springs!
Good thing i ordered the extra Poly bushings, too!
Thanks everyone!
post #12 of 18 Old 07-16-2011, 01:33 AM Thread Starter
jayvando707
here is a pic after the install with my 30 x 9.5 x 15's and one with 33's on 17's..... only until i save up enough scratch to get tires for my 15's!
and like i said..... i gained WAY more than 4.5"! i never knew just how BEAT UP my stock springs were!
post #13 of 18 Old 07-16-2011, 07:17 AM
Mameluke
Looks good, mine was the same way, ended up gaining way more height than planned. It will settle some
Mameluke is offline
post #14 of 18 Old 07-21-2011, 07:15 PM Thread Starter
jayvando707
its been 5 days.... My YJ rides smoother than my dads TJ with a 4" lift!
post #15 of 18 Old 07-21-2011, 09:19 PM
imstillatwork
What's your rocker panel height with the 33's & lift?
imstillatwork is offline
bds
Loud "clicking" noise coming from the rear end Mitcho11 TJ Wrangler Technical Forum 11 04-06-2011 11:58 PM
White "grease"? coming out of sides of diff. Jeffro3000 JK Wrangler Technical Forum 11 03-30-2011 02:48 PM
Jeep coming home Friday ThirdWave JK Wrangler Technical Forum 28 08-02-2010 10:21 PM
Pleas help with "crunching" sound coming from front wheel area Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 9 02-28-2009 08:39 PM
100 degrees this coming friday joeygeep YJ Wrangler Technical Forum 16 06-23-2005 05:09 AM
