BBD Drilled out....still drip'n - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > BBD Drilled out....still drip'n
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-20-2002, 11:28 AM   #1
Plink
After I drilled out the idle tubes they still drip...any idea why??? If I can't get them to stop dripping I going to drill them even bigger. Come on guys help me out here a little!!! Thanks!
[FONT=tahoma][SIZE=3][COLOR=black][B]87 YJ 4.2[/B][/COLOR][/SIZE][/FONT]
[B]2" BL, 2" Shackle, 1.5" Black Diamond and Junk[/B]
[B]31 MTRs on MOABs[/B]
[B]Need new front and rear bumpers[/B]
[B]HAM: KB3JQS[/B]
Plink is offline   Reply With Quote Quick reply to this message
Unread 10-20-2002, 02:37 PM   #2
Meister_jeep
first off you should not waste your time with that. Buy a Weber or even better do like me and buy a HOWELL TBI (fuel injection) and there will be no more problems. Once your carter sh*ts its pants it does not get better
1988 YJ 4.2l
____________________________________________________
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline   Reply With Quote Quick reply to this message
Unread 10-20-2002, 10:08 PM   #3
Bob K
Spend $20 on a rebuild kit. Give the carb a good cleaning and rebuild. I'm very happy with my BBD carb. Drilled idle tubes and Juice Box ignition have made it all work even better.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline   Reply With Quote Quick reply to this message
Unread 10-21-2002, 04:16 AM   #4
Buzzard
I wouldn't drill them too much bigger. Did you clean them really good after drilling? I run a piece of wire in the idle tubes to be sure. I drilled mine out and it immediatly clogged up again because there was crud loose in the float bowl. It was just taking slightly bigger particles to clog it. I would also take the top of the carb off and look into the float bowl to see how much crud is in there under the floats. Just remove the floats and clean it out good, be careful not to get carb cleaner on the plastic accelerator pump, it could wreck it. I pulled a lot of these carbs apart and they all had crap in them. You also really need to blast out the passages with carb cleaner. Something clogged it to begin with, so its likly more crap is in there still. Also spend $3 for a new fuel filter.
The drilling is not always a permanent fix, you might have to get in there and clean out the idle tubes again, this just helps to pass slightly bigger stuff without clogging. I also find it easier to just take the top of the carb off to get to the venturi stack to do this, and less chance of those little choke plate bolts falling in the carb.
My Carter runs great now, especially after disabling the stepper motor while the metering pins were fully extended and doing the rest off the Nutter bypass.
Buzzard is offline   Reply With Quote Quick reply to this message
