BBD Carb - Vapor lock??? - JeepForum.com
post #1 of 4 Old 12-21-2001, 05:33 AM Thread Starter
Bob K
Bob K's Avatar
On rare occasions my Jeep will stall approximately 20 seconds after start up.I found that this happens because the float needle gets jammed into the seat. I can usually free it by tapping on the flange where it is located, other times I just disassemble the flange to free it. Replacing the needle and seat cures the problem for about six months. I've tweaked out the carb to where it otherwise runs quite well. I'm not planning a Weber upgrade anytime soon. Does anyone have experience or remedy for this?
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #2 of 4 Old 12-21-2001, 10:49 PM
holmes133
I was having similar problems with my 88 YJ and messed around with the carb for about 3 months before I finally just yanked the stock carb off and put a Weber on. I am sure all the guys in here that have the Webers will tell you the same thing...."Remarakble improvement in every aspect of performance." You can play around with your carb more or just bite the bullet and invest in a Weber.
88 YJ with a 78 258 bored .030 over,Weber,Nutter Bypass, Juice Box and Herculined. Paint Job, 2.5 lift and tires coming in the near future!
2002 WJ Limited, 4.0...all stock...the wife's car!
holmes133 is offline
post #3 of 4 Old 12-21-2001, 11:19 PM
odie
Is this the stock carb? if so they are prone for trouble look at upgrading to a weber k551 or k550 or if you have the dough fuel injection. I recently replace my carter with the k551 kit which has a 32/36 weber. NICE
odie is offline
post #4 of 4 Old 12-26-2001, 10:53 PM Thread Starter
Bob K
Bob K's Avatar
Any ideas how to prevent this problem with the BBD?
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Bob K is offline
Vapor lock? OKJeepin YJ Wrangler Technical Forum 5 06-07-2010 04:26 PM
Vapor Lock Apex TJ Wrangler Technical Forum 4 08-30-2009 05:59 PM
Vapor Lock???? why?? giggityjeeper YJ Wrangler Technical Forum 3 06-10-2007 07:02 PM
Not Vapor Lock...what is it? C2U5H TJ Wrangler Technical Forum 9 07-21-2005 08:06 PM
Vapor Lock??? bigjeep39 YJ Wrangler Technical Forum 1 07-04-2001 05:18 AM
