BBD Carb Mod, Oh Yah!! - JeepForum.com
post #1 of 11 Old 01-11-2002, 03:09 PM Thread Starter
Billy Badass
On my 88' YJ The idle fuel pick up tubes clog up and make it run like crap. You guys know what i'm talking about. Well i pulled them out to day took me about twenty minutes to do the procedure, didn't even have to pull the venturis out. I bored out the tubes to .0040" Very easy to do, the hardest part was to find the drill bit. They will never clog up again. I got some extra umph back in my jeep, and now it runs like a dream. The only side affect was that it raised my idle to 1100 from 650 rpm, that was easly fixed by idleing it down. Iwould recomend this fix to any one, if you need complete instructions let me know. I tried a .0032" overbore and it lasted three months before they cloged up, so I went a little bit bigger and now I have more bottom end torque. And no cloging. You'll love it!!
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
post #2 of 11 Old 01-13-2002, 09:37 PM
JeeperBill88
Since I was in the process of rebuilding my carb, I also drilled out the idle tubes to 0.040 and reinstalled the rebuilt carb today. Before rebuilding, my Jeep died about 50% of the time when coming to a stop. After drilling out the tubes, it did not die a single time when driving around on a test run...goood news.....
One question: How many turns did you back out the idle mixture screws on the front of the carb? I tried 2 1/2 turns for the test run, but plan on playing with them to try to smooth out the idle a bit.
Since you also live in Calif. it will be interesting to see if the drilling of the tubes will affect emissions testing during the next smog test....I have a spare carb with undrilled tubes for a swap out just in case...
Jeeper Bill
88 YJ, 4.2L, 5 Sp
2.5 In RE Lift
31" BFG AT KO's
JeeperBill88 is offline
post #3 of 11 Old 01-18-2002, 12:12 AM Thread Starter
Billy Badass
Well It's glad to know that some one used the mod, personaly I also backed out the mixture screws about 2 turns, but i'm still playing with it a little bit to find out for my self, right now it's at 2 1/4 turns and it is running fine. Tell me how you like your newly aquired bottom end, it has more get up and go than it used to. Try this with the nutter bypass after you finish emissions test, and you will find plenty more power.
I found out that is you run it to rich you will have trouble starting it in cold weather, so 2 1/4 turns worked for me.
Thanks for the reply.
post #4 of 11 Old 02-28-2002, 06:48 AM
stilllearning6
BB-- yes , I am interested in learning how you did the drill out of the idle tubes . I have a handheld portable battery operated hand drill . Is that suitable for the job? I am concerned about keeping the bit straight . Do you need to setup a bench jig to do this properly ? Is this a machine shop job ? I have done the idle jets clean out , seems to idle fine . I still wonder if it could be better . I am afraid to open a can of worms .
stilllearning6 is offline
post #5 of 11 Old 02-28-2002, 07:36 AM
warf
i was wondering how your carb did on really steep hills. that is where mine has all of its trouble. and also i was wondering if you could send me the instructions for that mod to my email it is warfnation@pirate4x4.com
87 JEEP WRANGLER WITH 258 SIX NOTHING MUCH ELSE YET
warf is offline
post #6 of 11 Old 02-28-2002, 08:41 AM
rodgersmc
If you check in the engine forums, BB has posted exactly how to do this... he used a hand crank. Any motorized drill and you run the risk of the bit moving around too much and screwing things up.
Good luck finding the bit ;-). I'd start with hobby shops.
BTW, tough luck for all you Californians... we don't even have inspections anymore here ;-).
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #7 of 11 Old 03-01-2002, 11:04 AM Thread Starter
Billy Badass
Chevk out the hobbie shops, or any electronics stoe. Go into a hardware store and ask for a 60g drill bit they should hav it. But you can do this mod with hand tools it is very easy.
I do have a posting in the engines section also with complete instructions on how to do it. Thanx,
post #8 of 11 Old 03-01-2002, 11:07 AM Thread Starter
Billy Badass
Mine had no problem passing emissions, it actually did better that it normaly did. It will still have trouble one steap hills but this mod will help a little bit. It due to the fact that you only have about 113 horse power, and that it is carborated.
Well take it easy,
post #9 of 11 Old 03-01-2002, 05:06 PM
Tommy Gun
Yo Billy,
I noticed you listed a plan for the Nutter on your carb. Isn't this illegal in California? I live here as well and would love to do it, but I also need to pass smog, as this is my daily driver. One more thing, is the JKBII Carb Mod, the name of the mod for drilling out the idle tubes with the #60 drill bit?
Thanks,
Tommy
Tommy Gun is offline
post #10 of 11 Old 03-01-2002, 05:17 PM Thread Starter
Billy Badass
Yes it is the name, this was the first post about this mod, I got so many resposes for the instructions that I postd them in a second post to satifie every one. The nutter bypass is illegal everywhere, but most places do not care. California on the other hand dose. So if you have an inspection coming up soon don't do it. If you make speical connection using male and female adaptors on the wiring you can always un hook it, hook the old wiring back up and the computer will reset itself.
Later.
post #11 of 11 Old 03-01-2002, 05:42 PM
Tommy Gun
Yo Billy,
I found pics for the JKBII Carb Mod at www.jeepz.com I still need to play with my idle. The mod improved my top end as well as my low end. Any time I step on the gas, the Jeep responds. I can pass cars while cruising surface streets as well as on the freeway. (I hit 80 today!)
Tommy out
'89 Wrangler Laredo, 4.2l a/t,ac,cd,cb,31s,JKBII Carb Mod
Daystar 1" lift and 1" shackles on the way
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 10:38 AM
carb adjustment on 88 6cyl carb onlyoneromeo YJ Wrangler Technical Forum 5 04-04-2009 05:56 PM
carb Q`s exavious YJ Wrangler Technical Forum 0 06-28-2008 09:07 PM
Carb on a 91 YJ Mr. Tobes YJ Wrangler Technical Forum 1 04-02-2006 08:25 PM
cj carb on yj muddy89yjeep YJ Wrangler Technical Forum 4 07-30-2003 10:02 AM
