Battery and Wiring Accessories - JeepForum.com
post #1 of 6 Old 04-21-2011, 07:13 PM Thread Starter
jhumphrey
I've started making out my lighting wish list and came across something that I thought I would ask....
What are you guys doing for all the multiple accessories you have going to your battery? There's not a lot of real estate around the positive and negative battery post for various lights, cb, winch, etc., so how do you keep everything neat around your terminals? Is there something out there that allows you to attach one wire to your positive terminal and then branch off (same thing for the negative)? Sort of like a quick connect, but more like a "power and/or ground pods". I just don't want my battery looking like a birds nest.
Thanks, hope that's not to confusing....
jhumphrey is offline
post #2 of 6 Old 04-21-2011, 07:25 PM
Nibbley15
Nibbley15 is offline
post #3 of 6 Old 04-22-2011, 07:46 AM Thread Starter
jhumphrey
Those are very nice, Nibbley. I had figured that you would use some sort of fuse block in the engine compartment to tidy everything up, but I wasn't sure. Do those fuse blocks you posted allow for you to run a certain gauge wire from the battery post and then distribute the power via smaller gauge wire? Im figuring you can....
post #4 of 6 Old 04-22-2011, 07:55 AM
j_colella1
I installed one of those fuse boxes last week. I love it. It cleans everything up under the hood and brings it all to one location. I hooked up 3 sets of aux lights, winch & air compressor. It even has a place to store a couple spare fuses.
There is a great write up on this site for its install. Do a search to read more about it.
j_colella1 is offline
post #5 of 6 Old 04-22-2011, 09:25 AM
timatoe
timatoe's Avatar
If I were to do it over I would use that block from West Marine, I bought a fuse block locally for about $12, it works but it's not as pretty. I use marine style connectors on the battery because they're easier to add to and easier to disconnect power when needed. The main power line going to the fuse block is a battery cable for a riding mower I picked up at the local O'Reilly's for like $3. I just mounted all of it to a small plate and attached that to the stock jack mount.
timatoe is offline
post #6 of 6 Old 04-22-2011, 01:23 PM
Nibbley15
You can run any gauge wire to the box, (fuse it of course); to the 12+ side, then distribute via smaller gauge from there. There is also a negative side, so you can run a big ground, and distribute from there.
There are some posts running around showing this set-up; I'll see if I can link ya too it.
EDIT: Here is the link:
http://www.jeepforum.com/forum/f20/h...l#post11222603
battery , hook up , wiring
06 wiring winch to battery. TheDirtyGeneral TJ Wrangler Technical Forum 1 01-13-2011 02:12 PM
axillary wiring system for all accessories jmohlerfaria TJ Wrangler Technical Forum 14 11-10-2010 12:25 PM
Battery Wiring for winch DougieFresh JK Wrangler Technical Forum 2 10-23-2008 07:44 PM
Battery wiring help fyrdriver Wrangler General Discussion 0 09-30-2008 01:25 PM
Wiring in accessories on a 2002...where? AgentZed TJ Wrangler Technical Forum 12 12-30-2002 12:20 PM
