Battery Tray Removal - JeepForum.com
post #1 of 7 Old 11-02-2011, 09:06 PM Thread Starter
szbaren3411
Removed my battery tray due to rust. I was wondering if there is a special type of paint that I should use rather than a normal rattle can? Let me know if there is a specific type of paint to use.
szbaren3411 is offline
post #2 of 7 Old 11-02-2011, 09:40 PM
AaronJ
If you want to keep it from rusting again due to battery acid then you can use this after you clean and prep it:
http://www.skygeek.com/345qt.html
Otherwise use POR15 or just clean/primer/paint it with a rattle can.
AaronJ is offline
post #3 of 7 Old 11-02-2011, 10:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
X2 on POR15
Luck Favours The Prepared
Anticanman is offline
post #4 of 7 Old 11-02-2011, 10:49 PM
1SASjeepster
battery tray
My battery tray was all rusted, so I had it sand blasted and galvanized. Now no more rust.
Take care,
1SASjeepster is offline
post #5 of 7 Old 01-23-2014, 06:49 PM Thread Starter
szbaren3411
I ended up prepping it down and using a can of black rustoleum. It looks good and has held up thus far. Probably going to use the expensive POR-15 on the tub when its time to refinish.
post #6 of 7 Old 01-23-2014, 07:04 PM
YJ4LIFE
dipped mine in vinegar for a few days. got most of the rust off. used wire brush on a drill for the chunky rust. primed and rattle can after.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #7 of 7 Old 01-23-2014, 07:08 PM
crackedcornish
sandblasted the rust off, then bedlined mine
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
battery , paint , YJ
battery tray Ahrnsbrak14 TJ Wrangler Technical Forum 31 06-24-2011 10:46 PM
Battery Tray dabjeep YJ Wrangler Technical Forum 5 06-23-2011 04:18 PM
Smittybilt Dual Battery Tray & Battery Temp Sensor. 05jeeper TJ Wrangler Technical Forum 6 07-23-2010 09:32 AM
second battery tray wtf? epeck87 TJ Wrangler Technical Forum 14 06-23-2009 09:04 PM
Need Help : Battery Tray TheJackel TJ Wrangler Technical Forum 11 04-17-2008 12:01 PM
