battery posts turning white - JeepForum.com
post #1 of 11 Old 08-14-2013, 05:00 PM Thread Starter
LordBear
so any who..i am pretty sure this jeep has a short but no clue where. and it is causeing the buildup.. have hard to replace the conectors 3 times now. so i cleaned everything up real good last time and got some spray to put on there ..and it is still whiting up with acid or what ever that is...brain fart at the moment.. so is there a way i can fix this..maybe by add another grounding cable or soemthing?
LordBear is offline
post #2 of 11 Old 08-14-2013, 05:43 PM
bpounds
bpounds's Avatar
I don't think a transient voltage leak causes that. It is caused by acid from the battery reacting with the connector. You probably need a new battery, and probably should also replace the cable clamps, or better yet the entire cable. It keeps coming back because the battery case is leaking, either around the post or maybe the fill caps.
bpounds is offline
post #3 of 11 Old 08-14-2013, 05:58 PM
jbrown73
^This
"The Constitution is not an instrument for the government to restrain the people, it is an instrument for the people to restrain the government....." - Patrick Henry
Originally Posted by Rproject View Post
The only thing I can say is to close your eyes. Seriously. If you close your eyes and pay attention to your finger tips, you'll be able to feel the nuts better and manipulate them easier.
jbrown73 is offline
post #4 of 11 Old 08-14-2013, 07:13 PM
Que89YJ
Clean them and then coat them in grease. It's Dissimilar metals oxidatIon because of electrolysis from the current across the battery terminals. Grease blocks the air so no corrosion can form
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 11 Old 08-15-2013, 07:52 AM
95YamJam
Don't use regular grease. Dielectric grease.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #6 of 11 Old 08-15-2013, 08:26 AM
Que89YJ
I use bearing grease or vasoline on all the ground points and terminals that are exposed. The key is to clean and attach them before you make the connection. It will keep air out and stop corrosion. The dielectric grease is more for the connectors because you need to worry about the grease breaking down the plastic and rubber of the connector. It will work just the same but it is more expensive and I recoat every year or when I give the underhood a good bath.
Que89YJ is offline
post #7 of 11 Old 08-15-2013, 10:07 AM
95YamJam
Dielectric grease is silicone based so it also has better temp properties than most petroleum based grease. Honestly its not that pricey if you get a large tube. The little tubes are a joke.
I do agree with thorough cleaning before grease application.
95YamJam is offline
post #8 of 11 Old 08-15-2013, 05:37 PM
bpounds
bpounds's Avatar
Greasing the connectors is a good idea. I've just used Vaseline, but I really like the aerosol can coating too. And the felt washers help.
BUT, the OP has cleaned and replaced the connectors repeatedly. If it keeps coming back, slopping a coating on there is not going to solve the issue. Batteries with cases that leak gas around the posts is fairly common, and I don't know any way to fix that.
bpounds is offline
post #9 of 11 Old 08-15-2013, 06:17 PM
Que89YJ
Good call Bpounds. If the battery is leaking then you are right. The felt washers are to stop the ground traces from water and minerals on top of the battery from conducting from the battery terminals. There is no way you can get corrosion if the air cant get to it. High resistance will also accelerate the corrosion. Clean ad coat positive and negative terminals on both sides and coat on both sides.
Que89YJ is offline
post #10 of 11 Old 08-16-2013, 06:33 AM
chuck172
My wifes Liberty had an awful problem with the neg. term. flaking white. I sprayed it with fluid film. End of problem.
chuck172 is offline
post #11 of 11 Old 08-16-2013, 08:22 AM
vadslram
The white is lead oxide, basically lead rust. It happens all the time lead is in contact with air, it's acceleratted by an electrical current stripping electrons.
so if your battery case has conductive crud on it like salt spray or acid mist from overcharging, the terminals will corrode faster. Those felt washers that parts places sell are water resistant and help block a circuit from forming. Best maintenance it to periodically clean batterywith a light baking soda and soap solution, making sure to keep the stuff out of the cells. Then coat the terminals with a water blocking grease. Dielectric is best for a few reasons. Less conductive, usually thicker consistency and better water resistance.
vadslram is offline
