Battery not charging - JeepForum.com
post #1 of 8 Old 08-10-2013, 04:12 PM Thread Starter
Smelly2u
New battery alternator is good starter connections good volt meter baerly above 9?
Smelly2u is offline
post #2 of 8 Old 08-10-2013, 06:33 PM Thread Starter
Smelly2u
How can I make sure my solunoid (sp?)is good
Smelly2u is offline
post #3 of 8 Old 08-10-2013, 09:37 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
I'm having déjà vu... Lots of current threads on this topic.
http://www.jeepforum.com/forum/f12/b...rging-1558267/
http://www.jeepforum.com/forum/f12/b...harge-1558859/
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #4 of 8 Old 08-15-2013, 04:30 PM
XJ93
I would bet that if everything else is fine, it's the regulator. Not sure on 92 but I know 93-95 the regulator was built into the ecm. I had the opposite issue with mine. Overcharging at 18.2v, not pleasant. Replacing the ecm took care of that, but now mine won't start on the first roll over like she used to... Give a little to get a little I guess.
XJ93 is offline
post #5 of 8 Old 08-15-2013, 05:35 PM
Que89YJ
91-95 the regulator is in the ecm. Pull the alternator and take it to be tested at any good parts store. Chances are the alternator is bad or the cables are bad. Check your fuses in the fuse block under the hood. The big fuses are the alternator output and there is a smaller fuse for control.
Que89YJ is offline
post #6 of 8 Old 08-16-2013, 01:43 AM Thread Starter
Smelly2u
Ok man will check thx
Smelly2u is offline
post #7 of 8 Old 08-16-2013, 09:25 AM
jsipe007
Que hit the nail on the head. I just had a few similar problems (charging at 19v and not charging). For me, the first fix was a wiring short.
Obviously, to start, check your fuses at the PDC. If all the fuses are good, check grounds. The ground i am specifically thinking of is the ground molded into the black box connector that attaches to the alt.
After testing the alt, if it comes back good, check continuity between alternator and ecm using a volt meter.
Also, the charging gauge is notoriously inaccurate on these jeeps. I would use a volt meter to check exactly what the charging voltage is when the car is on. There is a possibility that your gauge is no longer working.
jsipe007 is offline
post #8 of 8 Old 08-16-2013, 07:55 PM Thread Starter
Smelly2u
Great stuff you guys our very helpful cheers!!
Smelly2u is offline
