battery draining - JeepForum.com
post #1 of 4 Old 02-06-2002, 04:38 PM Thread Starter
bigins
battery draining
I HOPE SOMEONE CAN HELP. i have a 92'renegade and a battery problem. I thought it was the alternator that went out so i replaced it. got a new battery.and i am not getting a chage from the alternator or some thing is draining the battery what are some things i can check to see what is draining the battery. THANKS
bigins is offline
post #2 of 4 Old 02-06-2002, 10:23 PM
Mudpig
gotta 12 volt test light? Disconnect your pos. battery cable. Hook up test light between the wire terminal and the battery terminal. If the test light lights up you have a parasitic draw on your battery. Pull fuses one after another till light goes out. This fuse will be your problem circuit.
It's a jeep thing, I do understand!! 89 YJ Laredo,4.2L carburated. Chrome bumpers and grill. 31 AT's on 9x15 chrome modulars. Mustang GT buckets. 3" body lift and 1 1/2" shackle lift. Completely emission & computer free. Runs great!! Took the shackle lift out, they suck!!
Soon to be SOA with 35's
Mudpig is offline
post #3 of 4 Old 02-07-2002, 07:54 AM
cobra54
I once had a new Olds Cutlass that the battery kept goin dead on. Turned out to be a short in the starter.
93 Red YJ 2.5L
94 Red F-150 X Cab 5.0L
01 Black Cobra 4.6L DOHC
02 ZX3 Focus 2.0L DOHC
cobra54 is offline
post #4 of 4 Old 02-07-2002, 11:10 AM
JACKED
I have a 93 YJ with hard top and defroster and found out that the defroster was stock on but no light to indicate it was on. everytime I defrosted my windows then shut off the jeep bout 8 hours later DEAD. hope that helps, probally won't but good luck.
93 YJ 4.0L 5 speed. 3" body and 4" suspension lift. 35x12.5 MT tires.
JACKED is offline
Battery draining until dead FarFire70 TJ Wrangler Technical Forum 3 07-04-2009 03:52 PM
While I was draining my oil... Jeepster83 TJ Wrangler Technical Forum 6 06-10-2009 09:58 PM
What is draining my battery? angryjohnny TJ Wrangler Technical Forum 6 03-05-2009 08:54 AM
How to remove the doors without draining the battery question tandbwms TJ Wrangler Technical Forum 16 02-05-2007 10:56 PM
alternator whine and draining battery littlejohn YJ Wrangler Technical Forum 1 09-08-2004 03:51 PM
