Quantcast Battery burst again! What Gives - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Battery burst again! What Gives
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-09-2009, 11:51 AM   #1
mylogylo
So this morning I had to replace my battery for the second time in a year. They both ruptured and leaked all over the driveway. Why would this happen? I did find that the positive cable appears to have seen some serious heat. It is brown and cracked now instead of red. What gives? Any thoughts?
The only electrical accessories I have is an electric fan, and some cheasy fog lights.....so far ;-)
mylogylo is offline   Reply With Quote
Old 04-09-2009, 11:58 AM   #2
saharadream
check all your wiring that would go to the battery and make sure nothing is grounding out or any chaffed wires. if your positive cable grounds itself out someplace like on the frame or motor it would make it heat up therefore causing your battery acid to boil and crack/explode
saharadream is offline   Reply With Quote
Old 04-09-2009, 12:01 PM   #3
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
Have your alternator professionally tested.
Most likely, the internal regulator is dying and allowing an overvoltage condition.
Patrick
Holley Carb thread
zeus87gn is online now   Reply With Quote
Old 04-09-2009, 12:05 PM   #4
EABiker
Yep! This would be my first step.
EABiker is offline   Reply With Quote
Old 04-09-2009, 12:49 PM   #5
mylogylo
I had the guys at Checker test the charging system. They just hooked the tester up to the battery while it was running. Is there a better test I should have done?
Old 04-09-2009, 12:52 PM   #6
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
The alternator has to be spinning to test it.
What did they tell you?
Is there an electrical auto shop in your area?
They have better knowledge to diagnose this.
Patrick
Holley Carb thread
Old 04-09-2009, 02:42 PM   #7
mylogylo
They said the alternator/charging system tests out fine. His guess was that at somepoint the cable got fried and now it is just toasting the battery everytime.
I can figure out and fix most things, but troubleshooting the electrical side is certainly not my specialty Time to buy some brews.
Old 04-09-2009, 02:46 PM   #8
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
What I would do is replace all of your batt cables and ground cables to start with.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 04-09-2009, 02:53 PM   #9
EABiker
The voltage regulator may be intermittent, and it was OK at the time they tested it. Keep and eye on your voltmeter when you drive, and watch for a higher than usual voltage. Overvoltage in will cause a battery to swell more often than overcurrent out.
Old 04-09-2009, 05:02 PM   #10
laybackman
laybackman's Avatar
High resistance in corroded wires may very well be the culprit. But usually other troubles happen also like trouble starting after you hit a bump or move the battery cables around. Make sure you have the right alternator in stalled also.
Blowing up two batteries in one year is cause for concern....plus it can get messy and expensive. The alternator charging circuit is not controlled internally but through your PCM's field generator circuit located at pin #20. Check that wire for exposed copper.
If that circuit was bad inside the PCM I would suspect that your CEL would snap on. There are several trouble codes to look for, in that case, #41 and especially #46.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
Life is not what it's supposed to be. It's what it is. The way you cope with it is what makes the difference.
I think we should place all of our elderly in prisons. They will get a shower a day, video surveillance in case of any problems, three hot well balanced tailor made meals a day respecting their religious beliefs and nutritional needs, access to a library, computers, TVs, gym.
Put criminals in nursing homes. They will have cold meals, lights off at 7pm, one bath a week, live in a smaller room AND will be forced to pay $4,000- $8,000 a month!
It's pretty damn sad that we treat prisoners better than the elderly.
laybackman is offline   Reply With Quote
Old 04-09-2009, 11:48 PM   #11
87TPIYJ
1987 YJ Wrangler
if your wire is burnt, then your amperage is to high. something is drawing to much current for that wire to handle. check the positive junction box and all the wires coming from it. in all likely hood you are grounding some where. and with that wire being the way it is you are very likely to start an electrical fire! no bueno.
new 350 installed and running strong!
http://www.jeepforum.com/forum/f12/replacing-305-350-a-747494/
87TPIYJ is offline   Reply With Quote
Old 04-10-2009, 07:37 AM   #12
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
This may all be tied together.
The corroded cables are causing a voltage drop across the battery, thus creating higher currents than the batt or cables are designed to carry. Especially during starting. The alternator is trying to put out more power across those cables and just adding to it.
Yes, definetely replace the cables if they are corroded and/or burnt.
Have your alternator checked out by an electrical specialist.
I'm guessing Checkers is a parts store. They aren't specialists.
Find an elecrical repair shop and they can help more.
Patrick
Holley Carb thread
Glock Forum
