Bastard Packs (Leaf Springs) - JeepForum.com
post #1 of 8 Old 08-25-2010, 05:43 PM Thread Starter
jeepaholic91
A guy on another forum mentioned goin soa with bastard pack leafs. He said the guy used a 4" yj main leaf and stock yj leafs the rest of the way down. Anybody ever heard of this? seems like it wouldnt work well but ive been wrong before
Louisiana Tech University
jeepaholic91 is offline
post #2 of 8 Old 08-25-2010, 05:55 PM
E_ROCK
I guess I can't see why it wouldn't work.
I used Ford ranger bastard packs for the rear of my jeep. One main, another cut up main, and the rest of the pack.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #3 of 8 Old 08-25-2010, 05:58 PM Thread Starter
jeepaholic91
well it's not that it's a bastard pack it's that its a 4" main combined with stock leafs is the part i don't get.
post #4 of 8 Old 08-25-2010, 08:37 PM
1tuffyj
4" main leaf with stock rest of pack? am i being retarded or would that take some really strong spring clamps? the main would be a rainbow while the stockers would sit flat
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #5 of 8 Old 08-25-2010, 10:55 PM
E_ROCK
To me it depends on how he put the pack together and if the rig is SOA or under? Can you provide a little bit more info?
E_ROCK is offline
post #6 of 8 Old 08-26-2010, 09:47 AM Thread Starter
jeepaholic91
that's all the info i have from the guy. He did say it was soa though.. he just said he knows a guy that runs this.
post #7 of 8 Old 08-26-2010, 09:59 AM
Destr0
YJ stock springs are really soft, so the arch from the 4" spring will give arch to the "flat" YJ stock springs, just not the complete 4". Same principle is what I am working with on my build- the S-10 springs I am going to use will give 3" of lift on an XJ, and an XJ spring will give 2" of lift on the YJ- I am hoping for 3-4" of lift my just using the one main leaf from the S-10, but we will see.
It is the same as using an AAL- they will probably not last as long as a full pack, but for the price they work.
Destr0 is offline
post #8 of 8 Old 08-26-2010, 12:08 PM
E_ROCK
Leaf springs get much of the arch from the shorter springs of the pack. I agree with what was said above. If you uses the 4" main with stock leafs, it will be flatter than you would think. In most of the packs I have taken apart, it seem like the stiffest one is the 3rd leaf in the pack (2nd leaf away from the main).
With SOA, the main leaf is the top leaf. It will flex flat until it touches the other springs.
E_ROCK is offline
bastard packs? evoGibson YJ Wrangler Technical Forum 8 07-20-2010 05:02 PM
Bastard packs Lyterx YJ Wrangler Technical Forum 4 07-04-2010 02:41 PM
AAL's/Bastard packs- How do you do it/What leaves to use? impboy65 YJ Wrangler Technical Forum 13 11-24-2009 05:47 PM
Saggy Springs: Add-a-Leaf, Bastard Pack, or other option? snaustin09 YJ Wrangler Technical Forum 5 01-29-2009 06:30 PM
Leaf packs hmmhoyhoy YJ Wrangler Technical Forum 5 11-13-2005 12:38 PM
