bastard pack? - JeepForum.com
post #1 of 7 Old 04-01-2008, 03:03 PM Thread Starter
will_982
bastard pack?
I have a spring over with the arch slowly going in the opposite direction, just plain worn out ( 150,00 miles stock springs). Question is I have a set of rear 2 1/2 lift springs from my old CJ and was wondering if I could split this pack up and spread it out over my 4 stock springs and gain a little extra life out of them before I replace the four? Seems like it would be a cheap temp fix, all I would need is a couple spring clips, and a dismantle. Since I have the springover my U- bolts aren't boogered up from drag or anything. Seem worth it or any fore seen problems
will_982 is offline
post #2 of 7 Old 04-01-2008, 03:24 PM
pacodelahoya
1987 YJ Wrangler
I don't see where it would be a big deal, other than getting the front and back level. I see where people mix and match different spring packs all the time here. I got a 79 chevy 3/4 tone with all the springs on it yet, you can have em if you can figure out a way to get em. My company delivers packaging as far as altoona if you wanted to pm me or something. I'm pretty sure they are 2 1/2 inches, though they may be three. Anyone know without me having to run up to my mom's to the garage?
'80 CJ 5 w/360
87 Wangler build in progress 350, 350, np205, 5.38 gears, soa,d60/14 bolt,accepting donations for wheels and tires(just kidding)
2000 Grand Cherokee LTD w/4.7
Do they have AA for Jeeps?
pacodelahoya is offline
post #3 of 7 Old 04-01-2008, 07:13 PM
1992_Wrangler
I've heard that if you get a hold of a set of factory yj springs you can cut the springs eyes off the main leaves and use the main leaves as an add a leaf, using the four add a leaves that came off the same vehicle should help keep you level also.
They are the black shoes, white helmets and plain uniforms of one of Americas most successful programs. They are heroes, they are winners, they are Penn State football.
1992_Wrangler is offline
post #4 of 7 Old 04-01-2008, 07:24 PM
djcondo
cj leafs are narrow
- Dan
djcondo is offline
post #5 of 7 Old 04-01-2008, 07:26 PM
vtjeepthing
If I'm not mistaken the CJ & YJ leafs are different widths. That would cause some issues.
EDIT: SLOW
A big Jeep requires a bigger wallet!
vtjeepthing is offline
post #6 of 7 Old 04-02-2008, 02:46 AM
pacodelahoya
1987 YJ Wrangler
Yea,I know that stock cj springs are 2 inches but the op said 2 1/2 inches, maybe someone did a yj spring conversion on the cj??
'80 CJ 5 w/360
post #7 of 7 Old 04-02-2008, 07:19 AM
1992_Wrangler
CJ rear springs are 2 1/2" it's only the front springs that are 2"
S10 bastard pack installed in a YJ Uberjeep YJ Wrangler Technical Forum 18 12-18-2009 09:21 PM
Bastard Pack. WalrusPaul YJ Wrangler Technical Forum 0 08-10-2009 03:58 AM
Saggy Springs: Add-a-Leaf, Bastard Pack, or other option? snaustin09 YJ Wrangler Technical Forum 5 01-29-2009 05:30 PM
5 leaf pack front, 6 leaf pack rear???? UCF YJ'r YJ Wrangler Technical Forum 12 01-28-2007 07:56 AM
Why is the '02 TJ the bastard child? sgrim80 TJ Wrangler Technical Forum 14 06-03-2006 07:51 PM
