Basic Rusty Panel Repair -
post #1 of 3 Old 11-11-2008, 08:04 PM Thread Starter
Redwind posted a question on repairing steel panels and someone in the thread asked me to do a write-up, i didnt expect a write up so i didnt take before pics but this is what i got. I'm no expert welder, an this was my first panel repair experiment. this may not be the best way to do it, but this was easy for me
I used a hobart arc welder, pull-in pins, a cutting wheel, grinder, and plastic body filler.
I repaired my drivers side floor pan, rocker panel, and the bottom of the tail gate.
I bought a floor pan and rocker panel of JCwhitney, i ordered the CJ7 panels since the YJ was unlisted, they are identical just to clear that up for everyone whos talked to a quadratec rep who says they arent.
First i cut out all the rusted sheet metal in floor panel an cut the rocker panel to an inch above the jeep logo, the same for the tail gate, i trimmed the panels to fit, i ran a few holes threw them an used pull pins, i dont know they tech name, and pulled them in
you have to make sure you grind off all the paint where you plan to weld an around it
i pined the panels into place an welded a bead along the edges of them an then grind them down
then i used plastic body filler an covered the edges of all the panels i welded, i was really generous with the stuff because you grin it down to make a more flush look when your done an painted
i herc'd inside, covered up the ugliness
i'll take pictures again when its painted
SteveJcoYJ is offline
post #2 of 3 Old 11-11-2008, 11:27 PM
Did you weld it flush or overlap it? Can't really tell from the pics. Good Job BTW. Jeeps are meant to be cut up.
sprngrider is offline
post #3 of 3 Old 11-12-2008, 10:46 PM Thread Starter
an thanks
In order to be able to post messages on the forums, you must first register.
basic 3" rusty offroad lift 45caljeep TJ Wrangler Technical Forum 16 01-12-2010 08:16 PM
Need suggestions on rusty windshield fram repair....!! davenay67 Wrangler General Discussion 0 07-16-2009 11:12 AM
Rocker Panel Repair buckydano TJ Wrangler Technical Forum 19 01-27-2007 05:27 PM
Need a basic set-up! j_arabolos TJ Wrangler Technical Forum 34 11-28-2006 07:45 AM
Rusty Pan NamesMUD YJ Wrangler Technical Forum 8 03-07-2006 08:05 AM
