Basic Repair - Rear axle lug stud replacement - JeepForum.com
post #1 of 7 Old 03-19-2010, 09:06 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Here is a simple easy repair that I just did on my wife's '93 YJ's rear axle. I replaced it & took a few pics along the way. For anyone who has little mechanical experience & has never done this repair, it's very simple and will only take a few minutes.
So you have a lug stud that is broken or has damaged threads. How do you replace it?
First you jack up the rear axle & remove the wheel & brake drum.
Make sure the wheels are properly chocked, the Jeep is properly supported with jack stands, and the parking brake is OFF.
Rotate the axle until the lug stud you are replacing is at the 3 or 9 o'clock position (depending on driver or passenger side) so that the damaged stud is closest to the front of the Jeep. This will keep it from damaging the brake components as you drive it out. Use a large hammer to pound out the offending stud.
Make sure to retrieve the old stud if it ends up landing in the brake springs & hardware like this one did.
Spray a little WD-40 (or any type of light oil) on the new stud & insert it from the rear of the axle flange. Use a larger nut as a spacer between the axle flange and lug nut & tighten the nut until you can see the stud seated into the flange.
Here's some tips.
1) Get at least an extra lug nut or two. You will likely damage the one you use to pull the stud into place during the repair. Use a regular style lug nut that is open on both sides.
2) Use an impact gun if you can. I have a 110 volt impact gun that I bought from Harbor Freight for about $39.00, and it worked like a champ.
The parts store can look up the proper lug stud by model application. The YJ's use a 1/2" X 20 size lug stud.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 7 Old 03-19-2010, 09:11 PM
Fhajad
Would the repair for the front disc brakes be the same way? That's the one that broke on mine.
Good write up regardless.
Fhajad is offline
post #3 of 7 Old 03-19-2010, 09:30 PM
erockz
Mean max, I cant tell by the pic if you did this or not but, If you place a washer behind the large nut it allows it to spin some and also putting alittle grease between the friction surfaces but not on the stud itself actually helps in saving the lug nut. Otherwise as you showed, thats the easy way to replace a wheel stud front or rear withou goin and buyin the tool to do it. Which essentially does the same thing but costs more.
erockz is offline
post #4 of 7 Old 03-19-2010, 09:46 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks. The front ones are quite similar. You'll need to remove the brake caliper, & the brake rotor too.
No I didn't use a washer, but that is a great tip. Grease probably would probably keep the nut from being damaged. I wasn't planning on re-using the nut, so I did not take that precaution. Thanks for the tips!
Max
Mean Max is offline
post #5 of 7 Old 07-06-2015, 11:28 AM
AAK11
Stud replacement technique
This method works very well.
I used WD40 on the stud hole. Then a large, greased washer next to the hub surface. A spacer nut, with another greased washer, then the open-ended nut (replacing the lug for this task) to pull the stud into the hole.
AAK11 is offline
post #6 of 7 Old 07-06-2015, 11:40 AM
cKruzer
SHEEPDOG
cKruzer's Avatar
1987 YJ Wrangler
a lower grade spacer and a taper nut will work well too as seen in max's photos.
1987 Frankenstein Street Queen.
Target: 5.3L; AX15; NP231; D44/D60; 4.88s; 36s
הָיָה הָיָה הָיָה
cKruzer is offline
post #7 of 7 Old 07-06-2015, 07:12 PM
rustbelt
Thanks Max for the post. I know at least 2 studs I need to replace next week and your walk through was perfect timing. Us guys new to Jeeps appreciate these basic repair tips.
rustbelt is offline
Rear Wheel Stud Replacement 1995Moneypit YJ Wrangler Technical Forum 9 03-09-2010 06:50 PM
Rear Axle Repair pasinbuy YJ Wrangler Technical Forum 8 02-09-2010 04:41 PM
Rear crossmember repair / replacement trucknut YJ Wrangler Technical Forum 10 03-13-2009 10:21 PM
Basic Rusty Panel Repair SteveJcoYJ YJ Wrangler Technical Forum 2 11-12-2008 11:46 PM
Rear wheel stud replacement Prot JK Wrangler Technical Forum 3 01-07-2008 09:29 PM
