Basic Repair - Front end alignment - JeepForum.com
 2Likes
post #1 of 45 Old 03-19-2010, 08:39 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
My wife's '93 YJ had developed an issue with wandering lately, so I decided to check the alignment. Jerry (JeepsOLot here on JF) came over to the shop & helped me out today, so we took some pics to show you how we did it.
We jacked the Jeep up & checked over the front end components for excessive play. Everything checked out fine, so we moved along to setting the "toe" adjustment.
Here's the main component of my high tech, state-of-the-art homemade alignment machine.
Yes, it really is a chunk of 2X4 with a 16 penny nail driven through it & then bent over a bit.
In this picture, the wood was moved back until the nail lightly contacted the tire, and then the tire rotated AWAY from the nail for a full rotation.
You will get a nice thin line completely around the tire like this one. Do this on both front tires.
Now measure the distance from one tire mark to the other. Measure on the front of the tires, and again in the rear. I usually measure right at the height of the leaf springs, so I know I'm measuring in the same place each time. It makes no difference what number is, only that you get an accurate measurement. Adjust the tie rod until you have 1/16" to 1/8" LESS in the front. This one measured the same front & back, so there was no toe-in at all. I adjusted it to 1/8" toe-in & it completely changed the way it drove. No more wandering, and the wheel returns to center (after turning) promptly.
I have a Rocky Road OTT high steer kit on this YJ, so I didn't go into making the adjustments in this thread, as the steering linkage is quite different than the stock setup.
I hope this helps!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 45 Old 03-19-2010, 09:01 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Wow, that nail in the board is a great idea. A heck of a lot easier than measuring across the whole tires. I've always used this link in the past, even though it's a TJ, the adjustments are the same. I'm going to use the nail next time.
Basic Jeep Front End Alignment
calpbs likes this.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 45 Old 03-19-2010, 09:05 PM
88YJtoCJ
Max, one of these days I'm gonna drive to the east coast of Florida so we can have a beer. You have any good wheelin' places out by you?
88YJtoCJ is offline
post #4 of 45 Old 03-19-2010, 09:13 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
We have 1 place near us, and it's "okay" at best...
But the beer on the other hand.....
Anytime!
Max
Mean Max is offline
post #5 of 45 Old 03-20-2010, 05:50 AM
YJ-Jer
Thanks Max! this beats the hell out of my, adjust, drive, adjust, drive, adjust, drive technique :-)
-Jerry
Originally Posted by unknown
"You know you drive a YJ when you run over a shadow and feel the steering wheel jerk."
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJ-Jer is offline
post #6 of 45 Old 03-20-2010, 12:37 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
That is a cool trick, easier that trying to measure from the 'same lug' front and back.
Happy Wheelin'
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #7 of 45 Old 03-20-2010, 02:13 PM
xjoverkill
Cool. Thanks for sharing. Awesome.
98 XJ 5 speed
xjoverkill is offline
post #8 of 45 Old 05-27-2010, 09:25 AM
RockWoRM
RockWoRM's Avatar
Please clean up that oil spill before someone slips!
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #9 of 45 Old 05-27-2010, 09:32 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
WRM
Actually, it's worse than oil!
It's antifreeze!
Max
Mean Max is offline
post #10 of 45 Old 05-27-2010, 09:40 AM
Sleuthhound
Awesome write-up. Mine's been pulling quite severely. Might have to find myself a 16 penny nail or some such make a fancy alignment tool with.
Sleuthhound is offline
post #11 of 45 Old 05-27-2010, 09:50 AM
YJhobby
Chalk another great write up to Mean Max!
I think I just drove past a Jeep alignment tool someone lost on the side of the road! Finders keepers!
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
post #12 of 45 Old 05-27-2010, 10:04 AM
RockWoRM
RockWoRM's Avatar
Looks like Max is off line right now, but if you don't have said '2x4', you can simply scribe a line with a knife or sharp nail in the center of the tire. Some chalk works better, but most tires are dirty enough to make a mark. Mark both tires at the same lug/spot/level on each side. Since the Jeep is/should be on jack stands, alll you have to do is, with the help of a buddy, is measure the front, then rotate the tires 180* to the rear. Take the rear measurements using the exact same mark. Repeat back and forth until toe is set. This is basically exactly the same thing as the full nail scribe and gets you the same results. Just another/different way of doing it.
WRM
RockWoRM is offline
post #13 of 45 Old 06-08-2010, 10:25 AM
Reverb
Just a quick question here Max - wouldn't the measurement change with different sized tires or is it that small that it doesn't matter?
Reverb is offline
post #14 of 45 Old 07-21-2010, 03:49 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes it would, but I've had good luck with those numbers on 33" tires.
If you are inclined to do so, you could use more toe-in (like 1/8"-3/16") for larger tires, and less toe-in (like 1/32"-1/16") for smaller tires. As your tire diameter grows, the more exaggerated the toe-in measurement will seem.
Max
Mean Max is offline
post #15 of 45 Old 10-11-2010, 06:28 PM
InEmberClad
Maybe a dumb question, but which Tie Rod end should be adjusted for this? Or should it be both of them? What's the easiest way to make sure its not just one wheel with a toe in instead of both of them being equally aligned?
InEmberClad is offline
Basic Repair - Rear axle lug stud replacement Mean Max YJ Wrangler Technical Forum 6 07-06-2015 06:12 PM
Basic front brake question BlkBird TJ Wrangler Technical Forum 17 08-26-2009 07:49 AM
Front end lca alignment 05tjx TJ Wrangler Technical Forum 0 08-23-2009 05:30 PM
Basic Rusty Panel Repair SteveJcoYJ YJ Wrangler Technical Forum 2 11-12-2008 10:46 PM
Front End Alignment Lfoster200 TJ Wrangler Technical Forum 7 08-31-2007 06:01 PM
