Basic rear seat installation - JeepForum.com
post #1 of 6 Old 02-10-2009, 09:03 PM Thread Starter
K8INFL
Not sure why this is causing me so much trouble - I would think it would be easy. I bought my jeep a few years back and it came without a rear seat.
I put a thread on here and some members helped me get the seat and brackets. I got what I think is the right size bolts from the hardware store.
But the side seat hardware sticking out that looks like it should fit into the side wall brackets is too high. The bottom of the seat does have some screw in risers, but it looks as though I would have to remove them and put the seat on the rear floor to get it in the side brackets.
This just doesn't seem right. It can't be good to have the seat sitting on the floor...... Can someone tell me what height the side brackets should be from the floor - maybe they were put in short for some reason? Or can someone send me a picture showing what the installed seat should look like??
What am I missing (besides a brain) ?
K8INFL is offline
post #2 of 6 Old 02-10-2009, 09:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I don't have any pics handy, but the rear edge of the seat bottom sits pretty close to being on the floor.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 02-10-2009, 09:13 PM
lilBlackXJ
Mine is only roughly an inch from the floor. If you'd like I can run out and snap a picture. With a tape measure for referance.
- 1998 Jeep Cherokee XJ -
K&N filter, removed swaybars, 7" 6000k HID AUX lights.
Little innocent looking Jeep, geeting lockers and a budget boost soon.
lilBlackXJ is offline
post #4 of 6 Old 02-10-2009, 09:29 PM Thread Starter
K8INFL
so are there risers in the back on yours that is about an inch off the floor? Or nothing and the front bolts hold it in?
yes - a pic and measurements would be appreciated if you can.
Thanks!!
K8INFL is offline
post #5 of 6 Old 02-10-2009, 09:35 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks!!
There should be one rubber tipped "riser" stud in the center of the rear part of the bottom that sits on the floor. The seat "pivots" on the front 2 mounting pins to fold forward.
Mean Max is offline
post #6 of 6 Old 02-11-2009, 04:55 AM
JaikYJ
The two brackets that your talking about that look to be on the side of your inner wheel wells only fit the seat when the back is upright. It locks it in place. Then there is a little lever on side of the bottom of the seat on the drivers side that when you pull that up the back of the seat folds down. And you can lift the seat forward. The female ends of the seatbelts mount in the middle of the floor right behind the seat and and the male ends mount to the floor right behind each side of the seat.
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
Basic Maintenance - Seat belt reel service Mean Max YJ Wrangler Technical Forum 53 07-06-2016 03:56 PM
Back Seat Removal and Installation skimodave TJ Wrangler Technical Forum 3 06-16-2009 11:28 AM
98 Wrangler Rear Seat Installation darkbeast TJ Wrangler Technical Forum 4 12-21-2008 02:26 PM
Seat installation Questions shockwavetj01 TJ Wrangler Technical Forum 0 10-29-2008 06:09 PM
Seat Slider Installation tstaut YJ Wrangler Technical Forum 2 07-02-2008 10:29 PM
