Basic Maintenance - Seat belt reel service - Page 4 - JeepForum.com
post #46 of 54 Old 10-15-2011, 05:45 PM
--chris--
--chris--'s Avatar
Originally Posted by boujo View Post
Unfortunately i have to add tot he resurrection of the old thread, but my 95YJ seat belt does not look like that at all. When it is fully extended there is stitching in the belt to restrict any further extension, therefore you cannot see the retractor.
I tried using PB blaster on the sides, even though I could not see the plastic barrel, but it is till far from new.
Any ideas?
Same thing here with my 94. Weird, because i think i read further back in the thread a few people have successfully done this with the later model year YJ's.
--chris-- is offline
post #47 of 54 Old 10-15-2011, 05:53 PM
castorriver
Same here with my '95. It looks like I'll have to drill out the rivets holdin on the side bracket to get to the mechanism.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #48 of 54 Old 06-03-2012, 11:55 PM
tonymartin
So I'm going to revive an old thread here, but as somebody asked further back, are the front and rear also specific? My pass side front belt doesn't have the lock when under force (i.e. when you pull sharply it doesn't lock, so in a crash would be useless) so could I just swap the rear pass to the front pass or are they also too different to use in different locations?
Thanks Max
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #49 of 54 Old 06-04-2012, 12:00 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, they are all different front/back/left/right for '92 & newer. You need the correct one for each seating position, except for the rear belts that will interchange left/right.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #50 of 54 Old 06-04-2012, 02:17 AM
tonymartin
OK, thanks Max. Good job I asked really as I was going to do this when I got some spare time
post #51 of 54 Old 06-04-2012, 04:59 AM
ctm
Is there also a write up on how to clean out the steel ball mechanism in the seat belt. As I understand it, that is how it locks.....when the steel ball moves due to vehicle deceleration it pushes up on the latch to lock the belt. If the ball is dirty it will not move properly. Anyone have pics of this?
ctm is offline
post #52 of 54 Old 08-19-2012, 08:35 AM
Rich G
I did this maintenance and it made a world of difference, all the trips in the mud and water made mine rust and seize up.
Nice write up!
Rich G is offline
post #53 of 54 Old 08-25-2012, 10:56 AM
tonymartin
I am having trouble with my p. side not locking (didn't realize until I checked the other day after owning it fro a year and ferrying the wife around in it sometimes.... My bad!)
Anyway, the "ball" looks more like a tiny bucket and the latch can get very sticky and cause things to jam open, thus stopping it from locking. I got a couple of snaps for it.
This is the mechanism with the main cover taken off. I drilled the rivet out.
This is the inside with the casing opened up. The little silver thing with the yellow top is the weight which activates the lock
This is a close up to show you what is inside. It scares me a little to think that the teeth and the locking part are all plastic. No chance of rust but they are very fragile!
I think something has broken out of the weight as it appeared to be hollow, but some left over stuff was in there, as though it had been filled with something.
The latch seemed to only be operable if the ball was full of stuff and was putting pressure on both parts holding it in. Otherwise it would just fall out easily when the casing was opened.
I will try to fill it with something, like RTV silicone or even some gum just t check if that helps. If so then there is a fix added. If not, I need a new seat belt!
post #54 of 54 Old 07-06-2016, 03:56 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I have to update this thread a little bit.
A couple of weeks ago I pulled out my seatbelts to do some maintenance. And I discovered that they were both shot. The drivers belt wouldn't grab at all. If I had roiled or been in an accident, my seatbelt would have only stopped when it reached the end. The little plastic gear stop, which engages the lock was totally worn away. Tonymartin, I stole your pic for this. The arrow is pointing to the gear stop.
What it does is stop the belt drive, then the pressure moves the roller, and actuates the actual stop.
The passenger side still would grab the gear, but most of the gear teeth were worn away.
So if your belts don't grab when you pull them hard, it's time to replace them. I just replaced them yesterday. I bought them from Morris4x4 for $165.
I guess this is what happens when you're bouncing around on trails a lot.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - 4.0L serpentine belt tension adjustment Mean Max YJ Wrangler Technical Forum 37 03-30-2016 06:37 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
