Basic Maintenance - Seat belt reel service - Page 3 - JeepForum.com
post #31 of 54 Old 03-22-2010, 07:10 PM
newyj
this does work like new again, thanks MAX
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #32 of 54 Old 06-07-2010, 05:20 PM
kiitanak
will this work aswell if the seat belt, once its pulled, and then letting go, it will not retract into its normall position. will wd-40 work?
kiitanak is offline
post #33 of 54 Old 06-07-2010, 06:22 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
That's exactly what it's for. Reread the first line in the first post, and then read what I indicated for lube qualities in the text above the 5th picture in the first post.
WD-40 doesn't really have those qualities.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #34 of 54 Old 08-06-2010, 06:01 PM
Jungle_Jim
Thanks for the posting, this is the second repair I found help for here.
Jungle_Jim is offline
post #35 of 54 Old 08-06-2010, 06:06 PM
gunshw301
Great tip on the seat belts being side specific. I took mine off years ago and then just put them on not knowing this. I will have to look into it, 50 percent chance its right i guess.
gunshw301 is offline
post #36 of 54 Old 08-06-2010, 08:37 PM
Area.3.Fiftyone
Wow, perfect timing.
I was getting so aggravated with mine just yesterday and I was threating to cut the beotches out..... some major use of profanity was heard within a one mile radius of my Jeep.
I'll have to give em' a lube job and take a deep breath.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #37 of 54 Old 08-06-2010, 08:46 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
This is an old write-up Stan. You hadn't seen this before?
Max
Mean Max is offline
post #38 of 54 Old 08-06-2010, 08:51 PM
BriansCJ
1994 XJ Cherokee
Originally Posted by OtsiderCherokee View Post
Does anyone know where I can find a write up on how to do the same to the passenger side front belt on my 1999 XJ?
This is a nicely written piece!
Heres my write-up(in progress), of removing the XJ interior. It already covers the seat belts though.
http://www.jeepforum.com/forum/f11/x...ation-1081483/
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #39 of 54 Old 08-07-2010, 10:28 PM
LeJerk
2009 JK Wrangler
Quality Torx bits from... China?
LeJerk is offline
post #40 of 54 Old 08-08-2010, 05:49 AM
Area.3.Fiftyone
Max
Nope, this one slipped though the cracks.
I didn't see it until it got bumped up to the first page. I'm going to pull mine out in the next day or so and give them a shot of lube.
I've got some other mods I've been working on the last couple of days and this isn't on my priority list (yet).
post #41 of 54 Old 08-21-2010, 04:17 PM
thakoolaidkid
I just saw this one too, thanks Max. My driver side seat belt doesn't catch when I slam on the brakes. Between that and no airbag its been too risky to drive it so its gathering pine needles under a tree. I'm going to try this and see if it has any effect. I'll let you know how it works out.
'96 ZJ: Sold.
'94 XJ: Sold for scrap.
'01 TJ: Back in a Jeep after 3 years!
thakoolaidkid is offline
post #42 of 54 Old 06-19-2011, 09:24 AM
whitelightning
what if you cannot get the belt to fully retract? it is almost wound up fully and cant get it out to get pack to the proper posistion to reinstall
whitelightning is offline
post #43 of 54 Old 06-26-2011, 10:38 PM
woodscavenger
1976 CJ5
gonna have to give this a try on my TJ. they are aggravating me!
woodscavenger is offline
post #44 of 54 Old 10-11-2011, 06:06 PM
--chris--
--chris--'s Avatar
Just pulled the retractor off my 94 YJ. It had a totaly different assembly It lacked any visible parts, and it appeared as though all the mechanical parts of it were built into the housing.
Anyone run into that setup? Is there a fix for them?
--chris-- is offline
post #45 of 54 Old 10-15-2011, 02:38 PM
boujo
Unfortunately i have to add tot he resurrection of the old thread, but my 95YJ seat belt does not look like that at all. When it is fully extended there is stitching in the belt to restrict any further extension, therefore you cannot see the retractor.
I tried using PB blaster on the sides, even though I could not see the plastic barrel, but it is till far from new.
Any ideas?
boujo is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - 4.0L serpentine belt tension adjustment Mean Max YJ Wrangler Technical Forum 37 03-30-2016 06:37 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
