Basic Maintenance - Seat belt reel service - Page 2 - JeepForum.com
post #16 of 54 Old 01-22-2010, 03:32 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by BallerJeep View Post
hey, I need some help. What if I let is slip back in? Now it won't feed me any belt. Is this some sort of thing to prevent people from taking it off? Do I have to buy a new belt? Help needed fast, thanks.
It'll be fine. Just hold it perfectly upright, as in the 3rd photo of my instructions. This will allow the ratchet mechanism to "unlock" if you gently work the belt in & out.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #17 of 54 Old 01-22-2010, 03:37 PM
mrmud4x4
Originally Posted by jbolty View Post
Old wives are sometimes wrong.
Hey.....my ol' lady is never wrong.....hehehehe
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #18 of 54 Old 01-22-2010, 03:43 PM
YJBlues
YJBlues's Avatar
Great write up max, only thing I would add is that sometimes stubborn torx need the persuasion of an impact driver the first time you get them loose. And I use an alternative lubricant, I have excellent results with liquid graphite, it lasts a LONG time. If you just post a picture of me applying it, you'll see what I mean
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #19 of 54 Old 01-22-2010, 03:46 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I don't even know why, but I've never been a fan of graphite lubricant. Because of that mental block, I never have any on hand & never consider using it.
If you have had good results with it, by all means post up a pic!
You never know how many folks you might help out!
Max
Mean Max is offline
post #20 of 54 Old 01-22-2010, 03:50 PM
YJBlues
YJBlues's Avatar
Max
heh, the pic thing was a joke Mr. Picture man!
The application is exactly the same as yours, the difference being that for areas like mine, where road salt and grime are a part of the road conditions, the graphite won't attract or hold the debris that a standard lubricant will.
YJBlues is offline
post #21 of 54 Old 01-22-2010, 03:54 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Ah! I see!
I am really a "visual" person, so there is no doubt that I probably post more pics up on JF than almost anybody!
Max
Mean Max is offline
post #22 of 54 Old 01-22-2010, 03:56 PM
mdywglr4x4
Just ordered up some rear belts and front belts to remove some racing seats. Definitely will service the belts before install.
*2000 TJ* - Long Arms - Big Tires - Chrome Shafts - Locked and loaded + Body Armor
*1988 325iS* - Coils - 24v Swap - Sways - Road Warrior
mdywglr4x4 is offline
post #23 of 54 Old 01-22-2010, 03:57 PM
BallerJeep
Thanks Max! Wow, I was pulling and yanking like no other! haha. I though my dad was going to tan my hind end for breaking ANOTHER piece of my Jeep while trying to fix it. Thanks again! :-D
"Do not go where the path may lead, go instead where there is no path and leave a trail." - Ralph Waldo Emerson
BallerJeep is offline
post #24 of 54 Old 01-22-2010, 04:03 PM
YJBlues
YJBlues's Avatar
Ah! I see!
Max
Pics help as much or more than any explanation, your arsenal or visual aids astounds me,
YJBlues is offline
post #25 of 54 Old 01-22-2010, 04:10 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
You're quite welcome! Glad you got it all handled!
Have you looked through my photobucket albums? I take pictures of EVERYTHING I can think of that might help someone out!
Max
Mean Max is offline
post #26 of 54 Old 02-11-2010, 06:31 PM
Axl Jack
Is it possible to use the rear driver's belt to replace the front driver's belt? Mine does not work correctly, and even after I do this little maintenance, if it still doesn't work can I just swap out a rear belt to the front? I can't remember visually if they are vastly different, and I'm far away from my YJ currently so I can't just walk out to the garage to inspect.
As a disclaimer, I don't use my back seat, so I don't have to worry about anyone not being safe in the rear of my Jeep.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #27 of 54 Old 03-21-2010, 04:43 PM
Dewster196
Just did this and wow my drivers side I used to have to manually feed the belt back in after I got out what a difference I used marvelous mystery oil in an aerosol can.
Lets hear it for Max on a quality informative write up, you saved me $200.00 on new belts.
A Nation of Sheep Breeds a Government of Wolves!
Dewster196 is offline
post #28 of 54 Old 03-22-2010, 06:29 PM
HARLEYX2
1987 YJ Wrangler
Nice fix so Im not trying to highjack your thread. I work for a dealer and seatbelts are warrantied for the life of the vehicle. The goverment makes them do it for safety. Why not just go to the dealer and get new ones for free?
HARLEYX2 is offline
post #29 of 54 Old 03-22-2010, 06:41 PM
monkeyhouse
That is a valid point, but we are jeepers, we are of a different mindset...we FIX things! Of course new belts would rock!
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #30 of 54 Old 03-22-2010, 07:07 PM
only_in_a_yj
Is that true for every state?
2003 WJ, Limited, 4.7, Quadra Drive. Stock
94 YJ, 4" Lift, Winch, 33x12.50
only_in_a_yj is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - 4.0L serpentine belt tension adjustment Mean Max YJ Wrangler Technical Forum 37 03-30-2016 06:37 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
