Basic Maintenance - Seat belt reel service - JeepForum.com
post #1 of 54 Old 01-03-2010, 09:55 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Okay, so your seat belt "locks" while you're trying to extend it to put it on or lean forward, then it fails to retract when you remove it to get out of the Jeep.
So then you priced new belts & fell over from sticker shock.
RELAX! There is a simple fix that you can do to prevent the frequent locking & restore the enthusiasm in the retraction spring.
I fixed mine today, so I'll walk you through it.
Start with a quality Torx T-50 driver. I used a 1/2" drive bit that easily removed the rusty bolt that attached the reel to the body.
The attaching bolt can be located at the bottom of the seat belt reel.
Remove the bolt & then hold the reel perfectly upright and fully extend the belt. Hold the reel assembly in a fashion that will prevent the belt from retracting.
Once the belt is held in the fully extended position, turn the assembly over and you'll see part of the ratchet mechanism that locks the belt.
I use a spray lubricant that has a penetrating quality, and then also leaves a fair amount of lubricant after the solvent ingredient evaporates.
I found this Tri-Flow at my local Ace Hardware store. This is the first time I've used it and it seems okay.
Liberally spray the entire assembly.
Use the straw on the spray tip to get the lubricant inside of the assembly. The old adage of "MORE IS BETTER" is the perfect strategy here.
Grab your trusty container of "Anti-Seize" and liberally coat the attaching bolt threads and then reattach the reel to the body.
Now your old seat belts will work just like new!
For those that may be completely removing the reels & belts in order to Herculiner the tub or swap roll bars or whatever, DO NOT mix up the belts from left to right. They are different part numbers and are "side-specific" and they will not perform properly mounted on the wrong sides.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 54 Old 01-03-2010, 09:59 PM
YJake
Nice one Max!
I may try this later in the week on the driver's side seatbelt.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #3 of 54 Old 01-03-2010, 10:03 PM
sebastian22
Great write up Max! I need to do this to my driver side seat belt ASAP.
95 Black YJ
sebastian22 is offline
post #4 of 54 Old 01-04-2010, 12:02 PM
OtsiderCherokee
Does anyone know where I can find a write up on how to do the same to the passenger side front belt on my 1999 XJ?
This is a nicely written piece!
OtsiderCherokee is offline
post #5 of 54 Old 01-04-2010, 03:13 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
It should be a fairly similar job, other than removing the interior trim panels that cover the pillar posts. If I can get my hands on an XJ, I'll pull the trim panel off & snap a few pics for you.
Thank you.
Max
Mean Max is offline
post #6 of 54 Old 01-04-2010, 03:20 PM
jbolty
jbolty's Avatar
I have always been told to never lubicate seat belt retractors because it would attract dirt to stick in the mechanism.
jbolty is offline
post #7 of 54 Old 01-04-2010, 03:25 PM
Ingle47
I Just did this saterday
'05 Black WK Limited 4.7 /2" Daystar Poly/ rooftop tent/ cobra 29 ltb classic/ 265-75-17 Dynapro MTs/ Procomp 7" driving lights/ Saguaro switch panel/ 1.5" ws/ SuperChip/
'99 Blue WJ 4.7 / Stock
'89 YJ 4.2 /SOA/ 35-12.50-15 Tsl/ Cobra 29 LTB Classic/ XRC8/ Tube Fenders/ Side Armor/ 8.8" rear/ 1.25 WS/
Ingle47 is offline
post #8 of 54 Old 01-04-2010, 03:30 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I think that may be an old wives' tale. New belt retractors are lubricated at the time of assembly, so I can't see any reason not to lube them later on as the lube dries up & dissipates. The lubes that I use when doing this are never heavy or greasy, so the ability for the lube to hold any debris is much less than a heavier grease based lube would have.
I have done this a few times over the past few years and haven't had any negative issues. My Jeep runs without any top (okay, I use a mesh bikini top ) mostly year 'round. Because of this, the rain dries out a lot of the parts (seat belt reels, ignition lock cylinder, etc) and I stay busy re-lubing items that may need little or no attention in most "conventional" vehicle interiors.
Hope this helps!
Max
Mean Max is offline
post #9 of 54 Old 01-04-2010, 03:34 PM
jbolty
jbolty's Avatar
Hope this helps!
Max
Old wives are sometimes wrong.
On the other hand here on this end of the country we have fine desert dust that is like talc. It get everywhere. I have to change my air filter and oil about every 200 miles.
jbolty is offline
post #10 of 54 Old 01-04-2010, 03:46 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Well I used to live in SD County (North County, Oceanside) so I know what you mean about the talc style dust!
If I had a build-up of that kind of material, I would probably use a evaporative type cleaner (Brakekleen comes to mind) on the mechanism first, and then use a very light lube afterward.
Mine definitely need some attention periodically, having the belt hanging outside the Jeep after exiting, and not being able to lean forward enough to release the parking brake was getting old!
Max
Mean Max is offline
post #11 of 54 Old 01-04-2010, 04:59 PM
Ironworker709
Ironworker709's Avatar
Another GREAT write up MAX!
Mine has been doing this for a while and was wonderin what the heck was wrong...thanks again
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #12 of 54 Old 01-04-2010, 05:11 PM
Floppy
Floppy's Avatar
Good write up Max... My seat belts are brand new and I already have to do this.
1990 Jeep Wrangler YJ -
2001 Mustang GT Vert (supercharged)
2004 Lincoln Aviator (daily driver)
2006 Yamaha V Star 1100 Custom
1974 Volkswagen Super Beetle (sunroof and 1904cc motor)
1972 Volkswagen Super Beetle (wolfsburg edition)
Floppy is offline
post #13 of 54 Old 01-04-2010, 05:21 PM
OtsiderCherokee
Max
Thank you Max, now it just has to warm up enough for me to want to get out and work on it!
post #14 of 54 Old 01-04-2010, 05:26 PM
YJake
Screw it, I'm doing this now. Cold weather and all.
My passenger side belt needs replaced, but I can still fix my driver's side one for the time being. I hate shutting it in the door because it doesn't retract fast enough (or at all).
Time to bust out the PB!
Jake
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #15 of 54 Old 01-22-2010, 03:18 PM
BallerJeep
hey, I need some help. What if I let is slip back in? Now it won't feed me any belt. Is this some sort of thing to prevent people from taking it off? Do I have to buy a new belt? Help needed fast, thanks.
"Do not go where the path may lead, go instead where there is no path and leave a trail." - Ralph Waldo Emerson
BallerJeep is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - 4.0L serpentine belt tension adjustment Mean Max YJ Wrangler Technical Forum 37 03-30-2016 06:37 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
