Basic Maintenance - NP231J transfer case oil change - Page 3 - JeepForum.com
post #31 of 45 Old 07-13-2012, 09:04 PM
animal0307
Originally Posted by grivera View Post
Excellent write-up. In the first post, you indicated 2.2 pints of ATF, did you intend to say 2.2 quarts? Also, does it matter what type of ATF is used (MercIII; TypeF, etc.)?
Since you didn't your answer I'll ask also. Does is matter what type I use? I have an auto trans so if I can just use the same type in both it's one less jug to carry around.
animal0307 is offline
post #32 of 45 Old 07-13-2012, 11:07 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
At the time I originally created this writeup, I used the capacity that had been listed elsewhere because I couldn't recall exactly how much I had used. For the record, it takes just a bit less than 2 quarts of ATF when you simply do a "dump & fill" fluid service.
The type of ATF to use is 100% irrelevant, I recommend to use the cheapest available. Different types of ATF exist because of the different requirements needed in the friction modifier aspects of the different fluids, specifically with respect to the friction materials of the bands & clutch plates. Your transfer case does not contain any such material, therefore the friction additives in the different types of fluid are without consequence. Simple lubrication is the only goal.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #33 of 45 Old 07-14-2012, 11:33 AM
animal0307
Cool. Thanks Max
post #34 of 45 Old 07-24-2012, 06:15 PM
Ihartleafsprngs
Just a note, if you don't have metrics that big with you when you might need to do this ( for example after having to have a logger pull you out of an impromptu mud hole with his skidder). a 12pt 1 3/16 socket will fit the drain and fill plugs nicely.
Ihartleafsprngs is offline
post #35 of 45 Old 07-27-2012, 05:59 PM
animal0307
Here is how I refilled mine for anyone else that had troubles at first. Short wide funnel and a short piece of vinyl tubing. I had just enough between the extension housing and the tub to empty a whole bottle with ease. warning the tubing I used was fit snug in the fill port and I managed to over fill the case by a far amount and wasted a good deal into my oil pan.
post #36 of 45 Old 10-06-2012, 08:24 PM
StayClassy
Thanks for the write up.
I just did this a few hours ago, and it was super easy. The only bad part was that there was barely any old fluid in there! Good to go now.
StayClassy is offline
post #37 of 45 Old 06-26-2014, 10:17 PM
Nishbot
Just to be clear here, how much ATF fluid do you need for this drain and fill?
On this Fluid Capacities thread, it says 1.1 quart http://www.jeepforum.com/forum/f9/fa...cities-489932/
But you're saying 2.2 quart.
If anyone could let me know, that'd be great. I'll be diving into this this weekend.
Nishbot is offline
post #38 of 45 Old 06-26-2014, 10:37 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Apparently, the technical accuracy is elusive.
Since creating this thread a long time ago I have opened my own Jeep-only custom shop. I routinely drain & refill 231 transfer cases & have never exceeded 2 quarts. Usually it's around 1 & 3/4 quarts.
Don't over think it, grab 2 quarts of the cheapest ATF on the shelf & change it out.
Max
Mean Max is offline
post #39 of 45 Old 06-26-2014, 10:42 PM
Nishbot
Thanks for the advice Max!
ATF+4 usually comes in 1 quart bottles, and I didn't want have to buy 3 quarts if I didn't have to.
So I'll be picking up 2 quarts of ATF tomorrow and diving in.
Thanks again!
Nishbot is offline
post #40 of 45 Old 06-26-2014, 10:47 PM
Nishbot
By the way, Max, when you tighten the bolts, what torque do you tighten them to? Or if it's tight enough, that's all that matters?
Nishbot is offline
post #41 of 45 Old 06-27-2014, 12:19 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
It doesn't have to be ATF4, you can use ANY brand, type, flavor, etc. ATF that you want. The only difference between ATF specifications is the additives package, concerning how the fluid reacts to the friction material inside the transmission. Your NP231 does not have any such friction material, the fluid provides only basic lubrication.
Just snug. NOT gorilla tight, it's only aluminum!
Max
Mean Max is offline
post #42 of 45 Old 07-04-2014, 06:38 PM
Nishbot
Hey Max! Thanks for all of the advice! Did this today. Seriously took me no more than 20 min! One thing I didn't do was scrape to the right to check the magnet for shavings. Should I go back in there and clean that magnet? Also the oil that came out before, definitely was not ATF. It looked like motor oil. Is it ok to mix ATF with motor oil in the TC?
Also, mine had Allen bolts instead of 30mm bolts. Just saying..
Nishbot is offline
post #43 of 45 Old 10-04-2014, 05:15 PM
valingt
so what do i do if the owner before me put gear oil in the t-case? should i just drane and refill with aft+ or what. Plz help im rebuilding in now and want to know if i should clean out as much as i can or will some gear oil not matter?
valingt is offline
post #44 of 45 Old 08-31-2015, 08:17 AM
LenVino
Kinda looks like you left your drain plug out..
LenVino is offline
post #45 of 45 Old 04-03-2016, 07:03 PM
oldfarts
T case oil
How often do you perform this pm? curiosity
oldfarts is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - Engine Oil Change Mean Max YJ Wrangler Technical Forum 48 01-21-2015 01:18 PM
Np231j transfer case trouble shooting Blackfish YJ Wrangler Technical Forum 10 08-15-2014 02:27 PM
Transfer Case Expert needed! NP231j 231 eric411420 YJ Wrangler Technical Forum 5 12-15-2009 11:33 PM
Replace YJ Transfer Case NP231J jeephobbie57 YJ Wrangler Technical Forum 11 07-21-2007 05:01 PM
