Basic Maintenance - NP231J transfer case oil change - Page 2 - JeepForum.com
post #16 of 45 Old 02-24-2011, 06:21 PM
greyarea
Just as a note when that change was made from gear oil to motor oil the formulations of both fluids were different. Modern GL-5 gear oil is no longer corrosive to brass syncros and motor oil no longer contains even half high pressure wear additives.
Just a thought.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #17 of 45 Old 02-25-2011, 09:51 AM
GJeepFan
Just a thought.
Good luck,........it's all personal preference in the end, but NOTHING with a GL5 rating is going in my trans.
GJeepFan is offline
post #18 of 45 Old 02-25-2011, 05:11 PM
PaulEspo
OK, OK Ithink I got it
Manual Transmission & Tranfer case 10-30 motor oil, Should be Changed when?
Still 75-90 GL for Differential ?
PaulEspo is offline
post #19 of 45 Old 02-25-2011, 05:24 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
No.
10W-30 motor oil for manual transmission
ATF for transfer case
Gear oil for axles
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #20 of 45 Old 02-25-2011, 05:26 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I change all of my "case" fluids (trans, t-case, axles) annually or anytime those items may have been submerged.
Max
Mean Max is offline
post #21 of 45 Old 10-11-2011, 12:43 AM
tankinyj
just a question. i am doing my first full fluid change in my YJ. i fill the t-case through the fill plug correct? the write up doesnt say exactly where to fill it from
tankinyj is offline
post #22 of 45 Old 10-11-2011, 06:32 AM
Jims-87YJ
1987 YJ Wrangler
tankinyj, Yes through the fill plug.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #23 of 45 Old 10-11-2011, 09:30 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Seriously?
What other function could a "FILL" plug serve, if not for filling?
The next-to-last photo & caption couldn't possibly be any clearer.
Max
Mean Max is offline
post #24 of 45 Old 10-11-2011, 03:23 PM
cubewhiz
I have to agree with Max here. I can't think of any other purposes for the fill plug.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #25 of 45 Old 10-12-2011, 10:22 PM
tankinyj
wow... just a question. and to rebuttle you, the AX15 has a drain hole and a fill plug, yet you clearly show filling through the sifhter assembly. was possibly thinking the same thing
tankinyj is offline
post #26 of 45 Old 10-12-2011, 10:25 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Point taken. But the AX-15 fill plug has limited access, where the NP231 fill plug is readily accessible.
Max
Mean Max is offline
post #27 of 45 Old 10-13-2011, 09:51 AM
--chris--
--chris--'s Avatar
Originally Posted by Mean Max View Post
Here is a quick write-up on performing a fluid change on your NP231J transfer case. It's quick & easy, and will go a long way toward keeping your Jeep running smoothly!
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/YJ%20Mechanical/P1000089.jpg[/I MG]
Use a 30MM socket to remove the FILL PLUG FIRST to make sure you can refill it afterward.
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010228.jpg[/I MG]
Now drain the fluid. You can use an old piece of cardboard to keep the fluid from filling your skid plate. I was using a shop lift at the time, so I elected to skip the cardboard (regretfully) this time.
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010230.jpg[/IM G]
Let it drain until it drips out in individual drops. Then reinstall the drain plug.
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010231.jpg[/I MG]
I use the spout top from an old gear lube bottle on the top of the ATF quart bottle to refill the T-case.
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010234.jpg[/I MG]
I also have a spiffy little screw on funnel that makes refilling the quart bottles easier!
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010233.jpg[/I MG]
Refill it until it comes out of the fill plug, this way you'll know it's full!
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1010235.jpg[/IM G]
PLEASE BE RESPONSIBLE & recycle all old fluids!
[IMG]http://i702.photobucket.com/albums/ww27/meanmax/Maintenance/P1000473.jpg[/IM G]
Max
Good job on this write up, i was always nervous about this...and i guess it was for no reason. Easy job, ill do it this weekend
Originally Posted by rustywrangler View Post
Only thing to add would be to sweep out around with your finger to the right in the drain hole. The magnet sits right there and you can see if there are shavings on it or not.
Noted as well....is this in the FAQ?
--chris-- is offline
post #28 of 45 Old 10-13-2011, 04:50 PM
cubewhiz
I don't think that is in the FAQ. This shows where the magnet is in relation to the drain hole. Since the case is not transparent, I have to do it in two pictures.
cubewhiz is offline
post #29 of 45 Old 12-14-2011, 01:50 PM
Dakotah
Cool write up...where'd ya get that spiffy little screw on funnel? I need one of those!
Dakotah is offline
post #30 of 45 Old 04-13-2012, 04:34 PM
grivera
Excellent write-up. In the first post, you indicated 2.2 pints of ATF, did you intend to say 2.2 quarts? Also, does it matter what type of ATF is used (MercIII; TypeF, etc.)?
grivera is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - Engine Oil Change Mean Max YJ Wrangler Technical Forum 48 01-21-2015 01:18 PM
Np231j transfer case trouble shooting Blackfish YJ Wrangler Technical Forum 10 08-15-2014 02:27 PM
Transfer Case Expert needed! NP231j 231 eric411420 YJ Wrangler Technical Forum 5 12-15-2009 11:33 PM
Replace YJ Transfer Case NP231J jeephobbie57 YJ Wrangler Technical Forum 11 07-21-2007 05:01 PM
