Basic Maintenance - NP231J transfer case oil change - JeepForum.com
post #1 of 45 Old 04-08-2010, 08:04 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Here is a quick write-up on performing a fluid change on your NP231J transfer case. It's quick & easy, and will go a long way toward keeping your Jeep running smoothly!
Use a 30MM socket to remove the FILL PLUG FIRST to make sure you can refill it afterward.
Now drain the fluid. You can use an old piece of cardboard to keep the fluid from filling your skid plate. I was using a shop lift at the time, so I elected to skip the cardboard (regretfully) this time.
Let it drain until it drips out in individual drops. Then reinstall the drain plug.
I use the spout top from an old gear lube bottle on the top of the ATF quart bottle to refill the T-case.
I also have a spiffy little screw on funnel that makes refilling the quart bottles easier!
Refill it until it comes out of the fill plug, this way you'll know it's full!
PLEASE BE RESPONSIBLE & recycle all old fluids!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 45 Old 04-08-2010, 08:37 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Only thing to add would be to sweep out around with your finger to the right in the drain hole. The magnet sits right there and you can see if there are shavings on it or not.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 45 Old 04-08-2010, 08:43 PM
linusb
Thanks. This is on my to do list for the weekend!
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #4 of 45 Old 04-08-2010, 09:43 PM
bigorangeyj
doing this in the morning thanks
bigorangeyj is offline
post #5 of 45 Old 04-08-2010, 10:46 PM
bigorangeyj
could you tell me how much fluid i should buy for my tranny
post #6 of 45 Old 04-08-2010, 11:57 PM
minnbowhunter
Pick up 3 quarts, you won't use it all but you can use the leftovers to make your own penetrating oil
minnbowhunter is offline
post #7 of 45 Old 06-01-2010, 04:54 PM
vodadub
DAMMIT!
... Those 30mm bolts WON'T come out!!!
... and the one to refill is starting to go round. >_<'
vodadub is offline
post #8 of 45 Old 06-01-2010, 04:57 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by vodadub View Post
DAMMIT!
I used this.......
.....on this socket
.......to get one like that out of an NP249 the other day.
Max
Mean Max is offline
post #9 of 45 Old 06-02-2010, 09:34 AM
vodadub
Well ...
The bolt was starting to go round with this...
and this...
So tried with this...
and this...
Nothing was coming out of there so ...
Ended up using ALL of THESE...
And a little imagination...
FINALLY popp'd out
vodadub is offline
post #10 of 45 Old 06-05-2010, 10:03 PM
cubewhiz
I was able to get mine off with no problem using this:
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #11 of 45 Old 06-05-2010, 10:29 PM
imstillatwork
Drive up on ramps to drain as much as you can if yours is really old and nasty, then pour a 1/2 quart through.
imstillatwork is offline
post #12 of 45 Old 07-16-2010, 07:39 PM
Sleuthhound
Thanks Max!
Just did my rear T-case seal (what a pain), and had to put torch to my fill plug to get it to crack!!
Sleuthhound is offline
post #13 of 45 Old 02-24-2011, 07:50 AM
PaulEspo
I just bought my Wrangler and have the Haynes Manual. I’m trying to get this straight in my head. I have a 1995 YJ, 2.5, 5 speed manual trans. So the Manual Transmission takes SAE 75-90W GL-5 Gear Lubricant, Same as the Differential., BUT the Transfer Case takes Automatic Transmission Fluid. I though this was a misprint but you show Auto Trans. In the posting.
Can I use 75W-140 in the transmission and the differential as well for towing?
PaulEspo is offline
post #14 of 45 Old 02-24-2011, 08:49 AM
Sleuthhound
The AX-15 takes 10W30 oil (I can't comment and your AX-5, but I imagine it would be the same? I don't know anything about putting gear lube into a tranny, is that what the book calls for?) T-case takes ATF, Diffs take gear lube. Engine takes 10W30 of course. :P
post #15 of 45 Old 02-24-2011, 02:42 PM
GJeepFan
Originally Posted by PaulEspo View Post
I just bought my Wrangler and have the Haynes Manual. Iím trying to get this straight in my head. I have a 1995 YJ, 2.5, 5 speed manual trans. So the Manual Transmission takes SAE 75-90W GL-5 Gear Lubricant, Same as the Differential., BUT the Transfer Case takes Automatic Transmission Fluid. I though this was a misprint but you show Auto Trans. In the posting.
DO NOT use 75-90W GL-5 gear lube in the transmission. The GL-5 has additives that are BAD for the syncro's. The oil spec for our AX-5' and the AX-15's is 10-30 MOTOR OIL. This was confirmed by Chrysler! (see other threads out there about this). I put Mobil 1 10-30 "high mileage" in my AX-5 recently, haven't driven it much yet, but from what I hear it's like "butter" with the 10-30 in it.
The Front and rear Diffs take GL-5 rated GEAR LUBE, 75-90 weight, I used the Wal-mart brand "Synthetic blend" in mine, seems like decent stuff.
The Transfer case does take ATF!
Good luck, hope this helps!
GJeepFan is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - Engine Oil Change Mean Max YJ Wrangler Technical Forum 48 01-21-2015 01:18 PM
Np231j transfer case trouble shooting Blackfish YJ Wrangler Technical Forum 10 08-15-2014 02:27 PM
Transfer Case Expert needed! NP231j 231 eric411420 YJ Wrangler Technical Forum 5 12-15-2009 11:33 PM
Replace YJ Transfer Case NP231J jeephobbie57 YJ Wrangler Technical Forum 11 07-21-2007 05:01 PM
