Basic Maintenance - Fuel filter replacement - Page 5 - JeepForum.com
post #61 of 69 Old 11-13-2012, 08:44 PM
J-Quad
Originally Posted by PA_YJ19 View Post
It is a fuel hose my man, I just wrote it wrong. My gas and filter r all good, it's been on there for 2yrs n it is just fine. I change my filter yearly n they never seem to look odd inside.
Just trying to look out for ya, my friend!
I'm glad its still working out.
J-Quad
J-Quad is offline
post #62 of 69 Old 11-13-2012, 11:58 PM
linusb
I bought the factory elbow from jeep stealer. It's different sized at each end so to get good fit is worth the 20 bucks in my opinion.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #63 of 69 Old 11-14-2012, 10:00 AM
J-Quad
Originally Posted by VirginJeeper View Post
I replaced mine the day I bought my YJ.... My local dealer says they dont have any elbow for the top of the filter....
VirginJeeper,
Sounds like your jeep stealer needs to get parts from linusb's stealer.....
J-Quad
J-Quad is offline
post #64 of 69 Old 01-17-2013, 01:34 PM
t8tjt
fuel filter change follow up.
Regarding the hoses:
I had read here or in another post that the two little fuel filter hoses were no longer available at the dealer (for a 95) so I didn't bother to check. I took the two old lines and went to O'Reilly auto and matched them up. However, I made sure they were marked for fuel injection (higher pressures). Then I cut them to size (two different ID if I recall correctly). So far, no issues. Tom
t8tjt is offline
post #65 of 69 Old 01-17-2013, 03:18 PM
hobgoblin11
man I love write ups like this.. easy to read.. great pics. AWESOME POST.
Fule filter is alot bigger than I expected.
hobgoblin11 is offline
post #66 of 69 Old 01-18-2013, 06:11 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #67 of 69 Old 01-08-2014, 06:50 PM
Kudu
So the incoming line is a 3/8 what about the outgoing, 5/16? Please verify.
Can you rig it with generic fuel line and have some kink? The filter is large that there isn't much room to work with.
Tried to replace mine today PO had another model fuel filter with two larger ports so mine naturally with the new filter couldn't be tightened enough, causing a serious leak in the line.
Kudu is offline
post #68 of 69 Old 02-11-2014, 08:35 AM
Mambo_Dave
Another - "Thanks for the write up "!
I'm probably going to address this soon. Any word on Kudu's question as to fuel line sizes on the fuel injection 4.0's?
Mambo_Dave is offline
post #69 of 69 Old 09-02-2014, 07:28 AM
Dan Marino
I finally changed my fuel filter yesterday.
Great write up and photos here!
The job went amazingly well.
I was even inspired to paint the guard/bracket that protects the fuel filter since mine was rusty.
It is amazing how much sand and dirt was on the inside of the guard/bracket.
Fuel filter was very rusty on the outside. Jeep has almost 200,000 miles and it looked very old, but I was able to blow through it with no problem.
Everything went back together easily. Only got a little gasoline spilled on the garage floor that I ended up rolling into. haha.
Black 94 Wrangler S. Basic and fun!
Dan Marino is offline
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 09:34 AM
Fuel Filter replacement tommyO YJ Wrangler Technical Forum 3 07-02-2007 01:28 PM
Fuel Filter Replacement on a 91 YJ 4.0L JaySpencer66 YJ Wrangler Technical Forum 9 07-27-2006 09:29 PM
Fuel Filter replacement BeirBrennerE30 YJ Wrangler Technical Forum 11 04-18-2006 05:19 PM
fuel filter replacement? rolledthatho YJ Wrangler Technical Forum 4 01-25-2006 07:37 PM
