Basic Maintenance - Fuel filter replacement - Page 2 - JeepForum.com
post #16 of 69 Old 01-20-2010, 10:32 PM
TheDustMan
Mine has some sort of... "crush" clamp on the lines. Is there a special tool for removing those clamps? Or do I just rip them up and replace the lines and the old clamps with new fuel injection hose clamps?
The clamps look like this:
TheDustMan is offline
post #17 of 69 Old 01-20-2010, 10:45 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Those are single use clamps, IMO. I would just cut them off & use screw type clamps to replace them.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #18 of 69 Old 01-20-2010, 11:09 PM
TheDustMan
Max
I planned on it
post #19 of 69 Old 02-18-2010, 03:26 PM
clush
Nice write up! I will be using this in the next couple weeks - once the snow melts a little here in KY and I can get the jeep back in the garage!
clush is offline
post #20 of 69 Old 03-17-2010, 10:33 PM
cubewhiz
the procedure was exactly as described. very painless, thank you.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #21 of 69 Old 03-17-2010, 11:40 PM
bill8bud
wow I could have used this about 3 months ago. Nice write up!!!
bill8bud is offline
post #22 of 69 Old 03-18-2010, 08:59 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Great write up Max! Thank you!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #23 of 69 Old 03-25-2010, 02:44 PM
CrawlingForward
Thank you so much Max! This is exactly what beginners like myself need.
There's been a number of tasks like this that I've wanted to do and everytime I search, there is always an excellent Mean Max tutorial waiting for me! You are such an awesome asset to this community, so thank you for that!
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #24 of 69 Old 03-25-2010, 03:24 PM
Neo1130
2015 JK Wrangler
If yours hasn't been done and you have a lot of miles on you Jeep. Get it done! Mine made a HUGE difference in the way it starts and the way it runs at part throttle. The few filters I've changed before, it was hard to breath through. I couldn't breath through this one at all!
Also, I just went in and ripped the filter out without removing the gas cap or bleeding the pressure out.
Neo1130 is offline
post #25 of 69 Old 03-25-2010, 08:31 PM
ben6574
Thanks alot. That write up is really helpful for a new jeep owner.
ben6574 is offline
post #26 of 69 Old 08-15-2010, 12:04 AM
nhlx38
Thanks for the write up.... Just wondering before i do this, Would the fuel filter be the culprit of my issue?
I Always need to crank my jeep for about a min. or 2 before it starts, once it starts it runs fine. I figure It is either the Fuel filter, Fuel Pump, Or Crank pos. Sensor.
Any input?
nhlx38 is offline
post #27 of 69 Old 08-15-2010, 12:19 AM
stangfreak
i'd change the filter and see if it makes a difference. i've read a lot of "what's wrong?" threads on here that all sound like a possible dirty fuel filter. a lot of people don't realize how often it needs to be changed and don't get to it untill it causes problems.
"It's not getting older...It's getting newer part by part."
stangfreak is offline
post #28 of 69 Old 08-15-2010, 02:26 AM
nhlx38
Alright, thanks. I will probably get to it soon, I will try to report back and let you know if that was the issue.
nhlx38 is offline
post #29 of 69 Old 08-15-2010, 07:11 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Any input?
See if this applies to you.......
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
Max
Mean Max is offline
post #30 of 69 Old 08-16-2010, 03:28 PM
nhlx38
Max
That is awfully close.... I just went out and did exactly what the symptons explain, only differences is my check engine/shift light did not come on after the couple mins. and the buzzing came on about 30 sec. after i turned the key then shut off after buzzing for 10 sec. , then i waited about another min. and cranked it and it started right up.
should i attempt to do what the crash course in brain surgery thread says?
nhlx38 is offline
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
Fuel Filter replacement tommyO YJ Wrangler Technical Forum 3 07-02-2007 12:28 PM
Fuel Filter Replacement on a 91 YJ 4.0L JaySpencer66 YJ Wrangler Technical Forum 9 07-27-2006 08:29 PM
Fuel Filter replacement BeirBrennerE30 YJ Wrangler Technical Forum 11 04-18-2006 04:19 PM
fuel filter replacement? rolledthatho YJ Wrangler Technical Forum 4 01-25-2006 06:37 PM
