Basic Maintenance - Engine Oil Change - Page 4 - JeepForum.com
post #46 of 49 Old 07-29-2011, 12:19 PM
Newk76
What a little cutie, although I'm guessing she's not so little anymore!
We had a friend reccommend changing the oil pan plug because there is a rubber washer on it that will dry out. We have a slow drip coming from ours that we discovered while doing the clutch replacement, so obviously it needs it. Is this something that should be done on a regular basis? I've never even thought about it until now.
Newk76 is offline
post #47 of 49 Old 03-25-2013, 03:18 PM
YJUnit1988
1988 VJ
Ditto on the well done for a good basic maintenance how to -- if more jeep owners and vehicle owners in general practiced these basics the cost of maintaining baby would be a lot less.
YJUnit1988 is offline
post #48 of 49 Old 05-20-2013, 05:17 PM
Kristina
I also want to say thank you for this. Though the Hubbs and I have had our Jeep for a few years now, we had kids right after we bought the Wrangler (go figure, got the Wrangler then got pregnant ).
I'm not up and up on all the mechanics of it seeing as I haul the kids and dogs around most of the time in the Cherokee but find I am in the lovely predicament of spending next summer out in Montana with out the family, and Hubbs insists I take the Wrangler. Looks like now is the time I figure out how to do all the lovely maintenance and learn her quirks. I think we'll start with this, the oil change and the fluids. It can't be that hard right? Just like everything else, do it a few times and it's less intimidating.
Thank you again!
Kristina is offline
post #49 of 49 Old 01-21-2015, 01:18 PM
freakypenguin
Old Thread revival... Max, did you put all 6 qts of oil plus the 1 qt of marvel mystery in the engine for a total of 7qts? Just curious, always thought you could put too much oil in the pan and that was a bad thing...??
Just curious, I have a lifter tick going on and was gonna drop the oil out and put in royal purple 10w-30 and marvel mystery, but 7qts seemed too much.
Doobie Doobie Doo...
Beware the Penguin
/l ,[____],
l--L----[]lllllll[]-_
()_) ()_)==@=)_)
freakypenguin is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
