Basic Maintenance - Engine Oil Change - Page 3 - JeepForum.com
post #31 of 49 Old 09-27-2009, 08:13 PM
Dreygo
Aren't you supposed to use 75-90w gear oil in the tranny?
I'm just asking cause that is what I am using and that is what the book says.
USAF Pavement and Equipment Operator AKA: Dirtboyz Air Force Jeep Club Member 51
1995 YJ 4.0 I-6, AX-15, NP231 w/JB Super Short, Dana 30/35, 4.10 gears. 4" lift, 33X12.5XR15 Goodyear Duratracs/Cragar V Series, Homemade front bumper w/Hella 700FF
Dreygo is offline
post #32 of 49 Old 09-28-2009, 08:25 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Here's why I use 10W-30 motor oil.
The Mopar gear oil part number used to be 4897622aa, but when you search that part number you'll see it has been superceded by part number 4761839AC which comes up as 10w-30 motor oil. Here's a link to search the Mopar part numbers.
Discount Mopar Parts Jeep Dodge Chrysler parts & accessories with great service
It's the "new factory spec" lubricant.
Based on that, I use 10w-30 motor oil. I buy the Wal-Mart "Super Tech" store brand oil because it's cheap, meets all the API (American Petroleum Institute) grade qualifications and I change mine often, at least every 6 to 12 months.
Here's my write-up on the easiest way I've found to change the tranny oil in an AX-15 gearbox.
http://www.jeepforum.com/forum/f12/b...change-865520/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #33 of 49 Old 09-28-2009, 08:44 AM
JuniataCounty
JuniataCounty is offline
post #34 of 49 Old 09-28-2009, 10:34 AM
jeepjerryp7m8
1982 CJ8
Max, I pose this theory for you and anyone else.
I was told a long time ago that the high capacity oil filter was not as effective at filtering oil as a small or standard size filter because sub-micron size particles would build up around the edges of the already tiny holes in the filter material. These particles would make the holes in effect smaller allowing the filter to remove smaller impurities. So a smaller filter would "plug up" sooner becoming more effective, while a large filter would take longer to reach maximum effectiveness.
Keep in mind that the smaller filter would also loose its effectiveness sooner so an earlier change out would be needed.
I know people who change the filter quite often and top up the oil and extend change intervals quite a bit, often 4 to 6K or longer with almost all miles being on the highway.
jeepjerryp7m8 is offline
post #35 of 49 Old 09-28-2009, 08:48 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I was told a long time ago that the high capacity oil filter was not as effective at filtering oil as a small or standard size filter because sub-micron size particles would build up around the edges of the already tiny holes in the filter material. These particles would make the holes in effect smaller allowing the filter to remove smaller impurities. So a smaller filter would "plug up" sooner becoming more effective, while a large filter would take longer to reach maximum effectiveness. Keep in mind that the smaller filter would also loose its effectiveness sooner so an earlier change out would be needed.
Although I think that this may be a "technically" sound theory, to be honest if I have enough sub-micron particles in my engine's oil to be an issue, I'm looking to hard at all of this.
Extending drain intervals and/or running a synthetic oil is usually an attempt to save money or make an attempt at producing peak power or longevity of the engine in question.
Neither of these are on my list, as I spend WAAAY too much on our 3 Jeeps, and if my old '91 with 160,000 miles on it had any looser tolerances the pistons would be swapping holes!
All of this makes for good "shop talk" but when it comes right down to it, I think the only real reason I run a larger filter is because I can.
It's just a little something I figured out that I could do that makes me feel a little better/smarter, possibly in a placebo kind of way.
I guess in many ways I'm just a dumb redneck, and I'm okay with that, it's just my little place in this world.
Max
Mean Max is offline
post #36 of 49 Old 09-28-2009, 09:20 PM
YJake
Any pics or advice on a power steering drain and refill? Never could find out how to do that
EDIT
Found it here. http://www.jeepforum.com/forum/f12/a...-fliud-859596/
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #37 of 49 Old 09-29-2009, 03:53 PM
beerformeplz
1983 CJ7
Just changed my oil on my 4cyl and the larger oil filter works fine on it also. Thanks.
beerformeplz is offline
post #38 of 49 Old 07-23-2010, 07:40 PM
RaptorPDX
2003 WJ
Thanks alot for this breakdown. I'm new to jeepforum and just started tinkering with my 03 WJ and this was very helpful to a nervous newbie.
RaptorPDX is offline
post #39 of 49 Old 10-18-2010, 01:38 PM
SpideYJeep
Max,
Didn't you have a pic of a Fram PH8A on this, or a similar, thread/write-up?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #40 of 49 Old 10-19-2010, 06:27 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by SpideYJeep View Post
Max,
Hmmm, I don't remember.
I used to use the PH16 Fram (same as stock size) all the time and then I used a PH8A to see about the larger size once or twice, so some pics may exist of my Jeeps with the Fram filters.
However after all the negative press I've been seeing with Fram filters and the fact that I can buy Motorcraft & Mopar filters at Wal-Mart for the same (or sometimes less!) than the Fram, I decided to switch.
Max
Mean Max is offline
post #41 of 49 Old 10-19-2010, 11:00 AM
SpideYJeep
Max
Hmm...so what do you use for an air filter?
post #42 of 49 Old 10-20-2010, 06:28 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I have always liked the Wix brand premium filters, but I have typically been too cheap to buy a pricey air filter that I'll end up throwing away because I dunked my Jeep in some deep water.
Then I found out that my local auto parts store carries the whole line of Parts Master products, which are the discount line of parts. The filters (all filters, air, oil, fuel, etc.) are actually Wix filters, without the premium price.
Using my '91 4.0L as an example:
A Wix air filter #46123 has a list price of $12.29
A Parts Master air filter #66123 has a list price of $8.09
Same filter, different box.
As my parts guy said to me, "It's the same as store bread & Wonder bread, same stuff with a different wrapper."
Max
Mean Max is offline
post #43 of 49 Old 10-20-2010, 06:25 PM
SpideYJeep
Thanks again Max!
post #44 of 49 Old 03-11-2011, 09:14 PM
n8dawgbu
Thank you Max, this made my life a lot easier for changing it myself for the first time.
n8dawgbu is offline
post #45 of 49 Old 07-29-2011, 10:22 AM
RandyTJ
Originally Posted by cmsurfer View Post
That's interesting... I have never heard of changing the filter before draining the oil pan. I guess it's just the way my father taught me that I drain the pan first then change the filter...
Wow....I have been changing my oil for over 40 years.......always pull the plug first........I guess I'll have to give the other way a try.
Never too old to learn!!
White 2005 LJ, Rubicon, Rubicon Express 3.5 SuperFlex, Goodyear 315/75/16 MTR's, Pro Comp 97 16x8 wheels, UCF Tummy Tuck, 1" Prothane BL, 1" JKS MML,Tereflex Disco's, 10,000 lb. winch. CB Radio, Fire Extinguister, Synthetic Fluids, Driving Lights....
1999 XJ 6.5 Lift, Rusty's Long Arm, Four Link Rear Suspension, ARB Lockers Front and Rear, Alloy Axles....
RandyTJ is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
