Basic Maintenance - Engine Oil Change - Page 2 - JeepForum.com
post #16 of 49 Old 09-26-2009, 10:59 AM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Hey Max, I am planning on changing the fluids in my tranny and axles today, when are you sending the helper over?
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #17 of 49 Old 09-26-2009, 03:45 PM
cmsurfer
That's interesting... I have never heard of changing the filter before draining the oil pan. I guess it's just the way my father taught me that I drain the pan first then change the filter...
cmsurfer is offline
post #18 of 49 Old 09-26-2009, 03:52 PM
JuniataCounty
Mean Max (and/or any other knowledgeable person):
I have a new (to me) jeep. Before winter (and before it sees heavy driving) I want to make sure I change all the key fluids. I don't really know how well it was taken care of by the previous owner, but it seems okay. I have a standard transmission.
I plan on changing the oil, break fluid, power steering fluid, clutch fluid, break fluid.
Am I missing anything? I went to the FAQ, but number of the links appear to be broken, so if there are any useful guides out there, I'd love to know about them.
Thanks
JuniataCounty is offline
post #19 of 49 Old 09-26-2009, 04:03 PM
cmsurfer
Thanks
Are you going to change the brake fluid twice?
Gear Oil
Transmission
Tansfer Case
Coolant
cmsurfer is offline
post #20 of 49 Old 09-26-2009, 05:43 PM
JuniataCounty
The gear oil (75/90 or 80/90) is for the differential's right? I saw a great guide for that here on for forum....
I am very un-mechanical - what is the difference between the transmission & transfer case, fluid & location wise?
post #21 of 49 Old 09-26-2009, 05:49 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
AX-15 tranny drain
AX-15 tranny fill plug
NP 231J transfer case drain & fill plugs.
Here's my axle lube write-up.
http://www.jeepforum.com/forum/f12/b...enance-728231/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #22 of 49 Old 09-26-2009, 05:52 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Very nice writeup Max! Your helper is a little cutie!
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
post #23 of 49 Old 09-26-2009, 05:54 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Rick
Hey Rick!
Congratulations on the new arrival!
Max
Mean Max is offline
post #24 of 49 Old 09-26-2009, 06:55 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
LOL thanks Max. He is sleeping peacefully with his Grandma right now.
Rick
post #25 of 49 Old 09-26-2009, 08:13 PM
JuniataCounty
Thanks max, your write ups are always great. I really appreciate the help.
post #26 of 49 Old 09-27-2009, 11:54 AM
fireshadow
X2 on the Mystery Oil. I have been putting the stuff in every time I do a oil change ever since my dad taught me how to do my first one a long time ago. It's never done me wrong. I even put a little in my gas tank every other fill up.
1988 Jeep Wrangler, home made posi lock, team rush upgrade, motorcraft 2100 carb, warn m8000 winch, np231c front yoke, rc 2.5" lift, 1" lift shackles
Even my motorcycle has a square headlight(1984 Honda Saber)!!!
fireshadow is offline
post #27 of 49 Old 09-27-2009, 01:36 PM
johnroot01
hey max, i noticed your oil gauge actually registers your pressure. mine doesnt register at all, unless i driving and then it only goes up to the first tick mark. do you know whether it would be my sending unit or the guage itself?
95 YJ: 4" RC, 1" booms, 1" BL, 33x13.50x15 SS TSLs, 15" RCX steelies, minus sway and trac bars
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
johnroot01 is offline
post #28 of 49 Old 09-27-2009, 01:48 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Turn the key to the "on" position, disconnect the oil pressure sender wire & touch it to "ground" on the engine block or frame. The gauge should go to the maximum reading. If it does, then the sender unit is bad.
Max
Mean Max is offline
post #29 of 49 Old 09-27-2009, 03:07 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have always done it that way. not sure who told me so. I did it once by draining first and then the filter, I got a bath of oil out of the filter. Not gonna do that again.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #30 of 49 Old 09-27-2009, 04:09 PM
johnroot01
thanks max
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
