Basic Maintenance - 4.0L serpentine belt tension adjustment - JeepForum.com
post #1 of 38 Old 12-27-2009, 07:41 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Today we were getting a lot of Jeep work done, and one of the things on the list was adjusting the tension of the serpentine belt on my red '91 4.0L YJ.
The belt actually needs to be replaced, but until I get the new one I wanted to get the belt squeal under control.
Here is where I started, loosening the two 13MM bolts located at the rear of the power steering pump. I access these from the top, using a long 13MM boxed end wrench.
It is only necessary to loosen them about 1/2 to 1 turn.
Next loosen the 13MM pivot bolt located at the top of the power steering pump, just above the pulley.
Then loosen the nut located underneath the pulley that locks down the belt tension adjuster bolt. I used a 13MM shallow socket on a 1/4" drive ratchet.
Now you can loosen or tighten the belt tension using the belt tension adjuster bolt. Tightening the bolt will tighten the belt, loosening the bolt will loosen the belt. I used a 13MM shallow socket on a 1/4" drive ratchet for this as well.
The belt needs to be fairly snug to avoid squealing. It's really difficult to describe the tension requirement exactly, but tight is pretty descriptive. After tightening the belt to the desired tension, be sure to tighten all 4 of the mounting points.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 38 Old 12-27-2009, 08:32 PM
DirtyJeepBoy
Great write up as usual Max. I see me standing on the porch. Great picture of all our Jeeps.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
My Build:
BDS/BTF/MCE
DirtyJeepBoy is offline
post #3 of 38 Old 12-27-2009, 11:08 PM
jaycal3
Max, thanks - as usual its a great write-up. And yes, you beat me to the project so this will be helpful!
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is online now
post #4 of 38 Old 12-28-2009, 05:46 AM
idaholtby
One thing I found helpful with the 4.0L is to remove the stock air box (if so equipped). This gives you a little more room to get after that tensioner adjustment bolt.
Keep up the good work Max!
idaholtby is offline
post #5 of 38 Old 12-28-2009, 05:57 AM
VanBCguy
Good write-up and pics Max. Thanks!
VanBCguy is offline
post #6 of 38 Old 12-28-2009, 07:23 AM
coachholland
Quick question. Is there anything special about that nut that goes on the tension adjuster bolt or can I just pick one up at the hardware store? Mine is gone and I'm tired of using belt dressing.
'95 YJ 4.0 5-Speed with a mod or two...
coachholland is offline
post #7 of 38 Old 12-28-2009, 01:23 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Not special at all.
It's a 8MM thread X 1.50 pitch (I think) "flange nut" because there is a washer sized flange built in. But a regular nut & flat washer can be used.
Max
Mean Max is offline
post #8 of 38 Old 12-28-2009, 01:49 PM
Axl Jack
Originally Posted by Mean Max View Post
Max
Max, I dislike you, and here's why: You mentioned today, December 27th... yadda yadda yadda. In the photo everyone has their bikini tops on or no top! While I'm up here in PA spending $25 in kerosene to keep my garage warm while I did some work to my YJ. And every 3rd day or so I'm at the carwash washing the underbelly of my Jeep to get the dreaded road salt off.
You suck.
Sincerely,
Axl Jack
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #9 of 38 Old 12-28-2009, 03:33 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
You suck.
Sincerely,
Axl Jack
What the hell?
You don't have to go & sugar-coat it! Tell me how ya really feel!
I know, I run with no doors & the bikini top pretty much year 'round!
I had been running with no top on my YJ from around February until I got the mesh VDP bikini top in June. It's been on there since then.
Here's when I got it.
http://www.jeepforum.com/forum/f176/...p-call-796196/
Max
Mean Max is offline
post #10 of 38 Old 01-20-2010, 01:09 PM
ZeroGravity
Thanks for the write up Max! It seems like the little things can turn out to be the most difficult.
Even my Haynes manual was vague on the adjustment process for the Fuel Injected models, I probably would have rounded off the 13mm bolts thinking they were standard.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 38 Old 01-20-2010, 06:16 PM
pasinbuy
You suck.
Sincerely,
Axl Jack
Living is Florida really sucks. The damn sun never goes away.
Anyway Max I have a question. To adjust the belt on my HD I have a tension tool and I am suppose to put 10 lbs of pressure to the belt and adjust until I have, (If I remember right.) 1/2 to 3/4 inch of play on the belt.
Does the YJ have any specs as to what to adjust the belt to? I hate to adjust it too tight because I do not want to wreck bearing on alternators, pumps, and etc. Or stretch the belt due to ever tension. ???
pasinbuy is offline
post #12 of 38 Old 01-20-2010, 06:32 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Spec is 180-200 lbs. from what I have heard.
As soon as I get in the vicinity of my FSM I'll double check & make sure the correct spec is in this thread!
Here's a link to a belt deflection gauge, available through NAPA and other retailers.
HMC Int'l.; KRIKIT TENSION TESTERS
Max
Mean Max is offline
post #13 of 38 Old 01-20-2010, 06:52 PM
pasinbuy
Huh, How does this thing work? I50 lbs is allot of pressure to hold. I am sure that I am not understanding how this tool works.
Thanks Max.
pasinbuy is offline
post #14 of 38 Old 01-20-2010, 06:55 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks Max.
The tool fits on either side of the belt. It measures the force that is required to deflect (bend) the belt. Once the tool is on the belt, you tighten the belt until the scale reads the desired deflection specification. No holding required.
Max
Mean Max is offline
post #15 of 38 Old 07-29-2010, 10:25 PM
91NDJeep
Awesome post.
I spent hours trying to find the right bolts to adjust this damn thing. I knew it was the power steering bracketry that did it and got all of the bolts loose except the actual tensioner one underneath. Didnt even see it.
Thanks for clear pics and a great how-to.
*Veritas Aequitas*
91NDJeep is offline
1998 TJ 4.0 Serpentine Belt Tension skruft TJ Wrangler Technical Forum 1 03-30-2009 07:39 PM
Belt tension adjustment borysd YJ Wrangler Technical Forum 10 08-23-2008 04:35 PM
What should serpentine belt tension be? keithert TJ Wrangler Technical Forum 9 03-18-2008 05:46 AM
Serpentine belt tension? '01 4.0 Lord_Verminaard TJ Wrangler Technical Forum 8 10-08-2007 06:01 PM
258 serpentine belt tension Ryno YJ Wrangler Technical Forum 3 10-07-2005 12:10 PM
