Basic diff lube maintenance - Page 6 - JeepForum.com
post #76 of 86 Old 10-22-2012, 10:19 AM
Danny915
is synthetic or non synthetic gear oil recommended for the stock axles?
Friend-"Hey why are you so rough with it?" Me-"Dude listen, it's a Jeep, is what it was built for"
1988 Jeep Wrangler 5spd,4.2L,Weber Carb, Holley Regulator,Electric Fuel Pump, Goodyear Duratracs 31x10.5x15, ZONE 2" lift kit, RC stabalizer,
Danny915 is offline
post #77 of 86 Old 10-22-2012, 11:46 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Non synthetic. Well run whatever you want but I wouldn't waste the money on the expensive stuff.
Luck Favours The Prepared
Anticanman is offline
post #78 of 86 Old 10-22-2012, 01:32 PM
Danny915
That's what was hoping you would say haha, just got some now as we'll as ATF for the TC, debating on redline or amsoil right now for the tranny.... They say use no synthetic for BA 10s so ill look at the prices
Danny915 is offline
post #79 of 86 Old 04-09-2013, 11:17 PM
zomblake
I went to Walmart tonight to pick up fluid and they had synthetic 75w-90 GL-5, but only 2 quarts. I picked up those and a qaurt of non-synthetic 85w-140 GL-5. Will the 85-140 be alright to use?
zomblake is offline
post #80 of 86 Old 11-27-2013, 04:12 PM
dukeryder
Anyone know the capacity for the Dana 30 WITH a Solid Diff Cover? I put in 2.5 QUARTS and it wasn't even close to fill hole but this Double the normal amount.
dukeryder is offline
post #81 of 86 Old 11-27-2013, 04:24 PM
Opihi59
from here it gets rough
Opihi59's Avatar
http://www.jeepforum.com/forum/f9/so...pacity-516063/
From the TJ side of the house. It appears that opinions vary. You may have to leave it as you have it and see what happens--make sure it's not blowing lube out your vent line or out the ends of your axle past the seals.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #82 of 86 Old 02-04-2014, 05:09 PM
Richard_
nice write up
Richard_ is offline
post #83 of 86 Old 12-24-2014, 02:18 PM
hardrockminer
so what is the order for tightening the bolts on the diffs? couple posts referenced it but i did not find it
hardrockminer is offline
post #84 of 86 Old 12-24-2014, 03:23 PM
Opihi59
Opihi59's Avatar
There isn't really a sequence. Most posts mentioning specific bolts recommend leaving one of the top bolts turned in just a few threads so that when you pop the cover, it doesn't fall off into your drain bucket. Just do them all up finger tight so to speak, then tighten in a criss-cross fashion rather than like a clock. You'll be good.
Opihi59 is offline
post #85 of 86 Old 03-20-2015, 09:47 PM
geofri
Just had to chime in with a thank-you.
Simple job which you might laugh at someone being intimidated by, but with a simple write up I had no trouble.
Decided to get fancy and sand and paint the cover while it was off, so it's taking a bit longer.
'90 YJ-258i6-4.2l carb'd. Nuttered. 3" lift stock gearing and 265 70/r15 tires.
geofri is offline
post #86 of 86 Old 01-20-2016, 12:46 PM
JeepSolid
Great pictures!
I try to do the same and always remove the fill plug first. Good tip!
Thx
Check out my Jeep repair videos on YouTube at JeepSolid.com
JeepSolid is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
