Basic diff lube maintenance - Page 5 - JeepForum.com
post #61 of 86 Old 06-25-2011, 01:17 AM
BJsWrangler
just wanted to say thanks for the great write up...you've given me the courage to try this, so I've ordered a set of lubelocker gaskets. They should be delivered in about a week, which works out good, since that's when I'll get back from vacation.
Thanks!
Ben
"ROADS! Were we're going, we DON'T need roads!"
fuzz2010: "real jeeps don't have round lights, they have leaf springs"
tricked919: "Basic rule of thumb for me is if I see a front pumpkin, I give a wave. Otherwise they might as well be in a Corolla."
BJsWrangler is offline
post #62 of 86 Old 07-19-2011, 09:06 AM
Siva283
Does anyone know how much Gear Oil the Dana 30 and Dana 35 hold. I am planning to do mine this weekend but it is my only vehicle so once I start if I find I do not have enough I cant just hop in and run to the store and get more.
Siva283 is offline
post #63 of 86 Old 07-19-2011, 09:13 AM
Andywear
First post last picture.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #64 of 86 Old 07-20-2011, 04:22 AM
Siva283
The pics aren't showing up for me
Ask me how I know...
Siva283 is offline
post #65 of 86 Old 07-20-2011, 05:55 AM
Andywear
Gottca covered.
80W-90 Axle Lube
D-30: 2.5pints
D-35: 3.5pints
Have fun!
Andywear is offline
post #66 of 86 Old 07-20-2011, 06:13 AM
Crisbot
Great information guys. I didn't even have to ask, just look and read. You guys are the best resource I have found.
Crisbot is offline
post #67 of 86 Old 07-20-2011, 07:06 AM
Andywear
^agreed
This forum is worth WAY more than the book I purchased for the Jeep.
Andywear is offline
post #68 of 86 Old 11-11-2011, 08:19 AM
radei269
As usual, great info in this thread.
Changed transmission fluid last week, looking into the diffs now. How can I tell if my axles have LSD or ARB lockers?
Thanks
radei269 is offline
post #69 of 86 Old 11-30-2011, 11:53 PM
matrix311
Thanks for the post! I bought my first Jeep yesterday and just finished swapping fluids. Did an oil change, front/rear diffs and t-case. I honestly dont think the t-case or the diffs has ever had the fluids changed. The T-case fluid should have been red and it was a nasty thick brown color and same with both the front/rear diffs. Now they have fresh oil and are happy! I just need to go back out and check for leaks here in a moment as i just got home from my test drive. Everything seems good.
Now i'm going to do a coolant flush and transmission flush tomorrow.
matrix311 is offline
post #70 of 86 Old 08-27-2012, 06:44 PM
jimmybob67
Thanks
anyone???
jimmybob67 is offline
post #71 of 86 Old 08-27-2012, 06:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by jimmybob67 View Post
anyone???
Take a picture and post it. That's the easiest way to learn. Checking for air lines vs wires vs nothing coming out of the top of the pumpkin
Luck Favours The Prepared
Anticanman is offline
post #72 of 86 Old 08-27-2012, 06:53 PM
jimmybob67
far as I can tell these are bone stock 35/30 axles. Would they be limited slip?
post #73 of 86 Old 08-27-2012, 07:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Shouldn't be limited slip but folks have been known to swap things in from time to time.
post #74 of 86 Old 08-27-2012, 09:12 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks
Easy.
"Select-able" lockers like ARBs/Ox Lockers/E-Lockers will be activated externally. You will see air lines/cables/wires going into the differential housing & there will be controls in the cab. These require no special fluids or additives.
"Automatic" lockers like Aussie Lockers/Lock Right/Detroit Truetrac will have no externally visible parts, but will be easily noticed while driving on pavement due to locking/unlocking/ratcheting while turning. These require no special additives or fluids.
"Open" differentials are factory equipment on models with no traction control options. These can be identified by jacking up the Jeep & spinning one rear tire (while the non-running Jeep is in gear or Park) and seeing the opposite tire spin in the opposite direction. These require no special additives or fluids.
"LSD" Limited Slip Differentials can be identified by jacking up the Jeep & spinning one rear tire (while the non-running Jeep is in Neutral) and seeing the opposite rear tire spin the SAME direction. These REQUIRE synthetic fluid, or a separate friction modifier additive.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #75 of 86 Old 08-28-2012, 04:40 AM
jimmybob67
Thanks Max thats what I needed. I know a bit out axles but wasnt sure how to tell if I had lsd.
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
