Banks monster cat back on 95 - JeepForum.com
post #1 of 9 Old 07-31-2013, 03:18 PM Thread Starter
doclees
Has anyone installed this on the YJ? I can't figure it out. SHOULD be an easy bolt-on. Not happening. Tried every combo I can think of with no joy. That track bar about the axle is just in the way. thanks
doclees is offline
post #2 of 9 Old 07-31-2013, 05:16 PM
OKwranglerYJ
The track Bar should be in the trash.
http://www.jeepforum.com/forum/f12/f...e-well-953630/
OKwranglerYJ is offline
post #3 of 9 Old 07-31-2013, 05:17 PM
sprngrider
Snake the tailpipe into its spot however you can, then bolt up the muffler, then bolt or clamp to the cat.
1994 2.5L WRANGLER S.
sprngrider is offline
post #4 of 9 Old 07-31-2013, 05:55 PM Thread Starter
doclees
Not possible. No wiggle room with the track bar in place. Looks like it needs to come out. I've tried per instructions with muffler in first and tried with tailpipe in first. No room to even get close to mate ends. Does anyone know if you do need to lift the axle with a jack to take off spring tension?
doclees is offline
post #5 of 9 Old 07-31-2013, 06:01 PM
scramblered
I put a new tailpipe on mine a few years ago and while I have no experience with the Banks system I had to jack up the rear end to make it possible to snake it through there. Good luck, Dave
"Not all who wander are lost."
scramblered is offline
post #6 of 9 Old 07-31-2013, 06:04 PM
1992 renagade
When I installed mine I did it on a lift so it was easier, I think what you can try is lifting the Jeep by the frame and letting the rear axle hang down and slip it in that way.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications
Blue Mountain Jeep Alliance
Delaware jeep Association
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline
post #7 of 9 Old 07-31-2013, 06:47 PM Thread Starter
doclees
Well duh on me! I'm sure that could make enough wiggle room. Need to try it tomorrow. Thanks.
doclees is offline
post #8 of 9 Old 07-31-2013, 08:18 PM Thread Starter
doclees
Do you have the track bar installed?
doclees is offline
post #9 of 9 Old 08-01-2013, 02:47 PM Thread Starter
doclees
OK here was the deal. Brought it to muffler shop. 10 min later they saw that it had a different than stock catalytic converter and stuck back too far. Had to have part of the cat cut and welded to muffler. So it wasn't my error this time.
doclees is offline
