Banging noise in 4wd - JeepForum.com
post #1 of 2 Old 07-21-2001, 07:30 PM Thread Starter
mikeyjph
I just started having problems with my Wrangler in 4wd, (high and low) It makes a loud banging, or knocking noise whenever it's engaged and I'm moving forward, it seems to be coming from the transfer case. Any idea what this could be?
mikeyjph is offline
post #2 of 2 Old 07-21-2001, 07:48 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Check the u-joints on the front driveshaft - you may have lost a bolt on the saddle strap which holds the u-joint of the front driveshaft to the transfer case output. When you engage 4 wheel drive, the output shaft starts spinning and would throw the driveshaft all over the place if it's loose, making one heck of a banging sound. You wouldn't feel it in 2 wheel drive if its only the front driveshaft.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
load banging noise Studhorsey TJ Wrangler Technical Forum 3 04-07-2008 08:48 PM
Banging noise kaz1961 YJ Wrangler Technical Forum 3 09-30-2007 06:02 AM
Banging noise while steering? txtj79 TJ Wrangler Technical Forum 4 08-07-2006 06:13 AM
banging noise :) 40 Thieves YJ Wrangler Technical Forum 8 09-18-2003 02:43 PM
banging noise??? benman2002 YJ Wrangler Technical Forum 3 05-21-2003 09:58 PM
