Ball Joints, YJ, Problem Solvers?? - JeepForum.com
post #1 of 7 Old 03-24-2005, 04:22 PM Thread Starter
yoshisushi
yoshisushi's Avatar
Looking to replace the ball joints while I'm working on the steering system.
When I look them up at www.rockauto.com they list something called Moog Problem Solvers, even AC-Delco offers them. They are for offset camber adjustment. They offer varying degrees from one-half to a full two degrees.
Do I need anything like this?
Anyone have any balljoint replacement tips
yoshisushi is offline
post #2 of 7 Old 03-24-2005, 04:26 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
If your truck drives straight, no pulling left or right, I would get non-offset (stock) replacements. If you really want to be sure, you could get the truck's alignment checked before the job (assuming the present ball joints are not totally toasted). Then buy the offset you may need to correct it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 7 Old 08-17-2011, 12:18 PM
babbs
I have a 95 yj and I can't find the supper ball joints can anyone help me
babbs is offline
post #4 of 7 Old 08-17-2011, 01:07 PM
dtn8tr
Can you find the lunch ball joints?
Seriuosly try this...http://www.oreillyauto.com/site/c/de...0317&ppt=C0106
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #5 of 7 Old 08-17-2011, 02:02 PM
MJMPC
You need to fill out your jeep info .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #6 of 7 Old 08-17-2011, 03:15 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Originally Posted by babbs View Post
I have a 95 yj and I can't find the (s)upper ball joints can anyone help me
They are above the lower ball joints, and above the axle shaft u-joint. If you mean can't find replacements at the auto parts, go to a different auto parts.
Web Admin for
post #7 of 7 Old 08-17-2011, 05:03 PM
jbeebe
go with stock (non-adjustable). autozone's duralast balljoints are made by moog (i believe).
jbeebe is offline
Ball Joints? SuperWade2 TJ Wrangler Technical Forum 8 11-21-2008 05:04 PM
Problem turning left...I lubed the ball joints itchyandscratch TJ Wrangler Technical Forum 4 06-11-2008 11:00 PM
Tie-rod ball joints? cwildmann TJ Wrangler Technical Forum 3 06-27-2007 11:31 AM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 06:23 PM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 09:45 PM
