Ball bearing on tranny drain plug - JeepForum.com
post #1 of 7 Old 10-16-2011, 05:42 PM Thread Starter
jollyroger1
I have had my yj for a little over a month now,decided to start changing the fluids before winter.The tranny fluid looked good,had the gearbox smell,but I found a bearing a little bigger than a pea on the drain plug.It shifts good and is quiet,what could this be ,is it getting ready to explode,lol.Just wondering if anyone else has run into this
jollyroger1 is offline
post #2 of 7 Old 10-16-2011, 06:15 PM
panaceabeachbum
thats the detent ball for the shift mechanism, holds it in your selected gear , should have a spring also
panaceabeachbum is offline
post #3 of 7 Old 10-17-2011, 06:23 AM Thread Starter
jollyroger1
Thanks,I hope thats all there was floating around in there
post #4 of 7 Old 10-17-2011, 07:14 AM
jbolty
jbolty's Avatar
that's not the drain plug.
jbolty is offline
post #5 of 7 Old 10-17-2011, 07:16 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Assuming you indeed pull the drain plug, which is NOT on the 1" thick plate between the front and back halves of the trans. Then yup, detent ball. Unless someone rebuilding it in the past dropped one (doubtful), you may likely see a problem at some time. The detent system is mainly there to make sure two things don't happen at once, like 1st and reverse. I rebuilt my AX-15 a couple years ago, seem to remember there are maybe six of then in there.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 7 Old 10-17-2011, 07:19 AM
panaceabeachbum
hopefully it wasnt loose until you pulled the plug. It and its spring will be held captive when reinstalled and are neccesary to help keep the plate that moves the shift forks in the proper place
post #7 of 7 Old 10-17-2011, 07:55 AM Thread Starter
jollyroger1
Im pretty sure that was the drain plug,it was on the passenger side almost even with the front of the skid plate and it is magnetic,for good reason I see,guess I will keep my eye out for a used tranny just in case this one goes.Thanks for the replies
metal shards on tranny drain plug normal Slick101 TJ Wrangler Technical Forum 3 03-02-2011 07:06 PM
AX5 tranny - what size socket for drain plug? 89jeepnut YJ Wrangler Technical Forum 1 07-02-2009 10:39 AM
Looking to Install a Drain Plug to Auto Tranny Pan Thunderstrike TJ Wrangler Technical Forum 11 04-28-2008 09:36 AM
Drain plug for ax-5 tranny freeballer YJ Wrangler Technical Forum 3 11-09-2004 03:59 PM
manual tranny drain plug removal Q? PADI_Pro TJ Wrangler Technical Forum 10 09-08-2003 08:57 AM
