Ladies and gentleman, I present you with my master plan, step by step. The goal of this is to take my 95 YJ and make it a bit more highway friendly. I call it Project: Highway Readiness Program, or HRP. I know, unique code names are kicka**.
Initially, I was going to do all this at once, with the goal of being ready for school in September, but time, funds and other complications have foced me to break it up into phases.
Phase 1 is my transmission swap. I'm putting in a TH700R4 in place of the stock TF999. While turning out to be expensive, the payoff of having overdrive and a lock-up converter on the highway, and a lower 1st gear would be a all around bonus. The trans will be backed up by a NP231 C/J case, NO adapters. This project will have its own separate write up in time. WITH PICS! The whole swap will be documented closely, showing all the parts I used and the overall cost.
Phase 2 will be a Ford 8.8 rear, 3.55 gears front and rear, and a SYE and CV shaft. 8.8's in decent condition are actually hard to come by in my area, and this prevented me from putting it in so soon. The e-brake set up and brake line mountings will be written-up.
Oddly enough, Phase 3 has already been completed due to necessity. Stainless steel brake lines were installed, due to rotten lines failing one afternoon while on the road. While no pics, were taken, insight to the install will be shared. It was A LOT EASIER of an install than anticipated.
Phase 4 will be a myriad of small components, such as Taurus fan, Dodge 136 amp alt, and "rock lights" for the underbody.
Right now, the 700R swap is underway, with parts coming from Novak Adapters and HESCO. The t-case is out and under the knife, and the TF is set to come out tomorrow. Once the job is completed, and I have spare time at school, the write-up will begin. Much credit needs to be given to the folks that helped me get the know-how to get going here. Once i get the names in front of me I'll include them in the thread. Will post up soon.
