Bad YJ Vibrations - JeepForum.com
post #1 of 23 Old 01-03-2012, 08:45 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
Bad YJ Vibrations
Alright, so i bought a Rough Country 4" lift with the n2.0 shocks and put it all on and bought some 33" tires. Tightened everything down and took it out for a drive. Everything was fine but once i hit about 45 mph it started vibrating BAD. I could hear it like when you start to run off the road on the interstate. The lift kit came with driveshaft drop brackets so im thinking its not that but i could be wrong. Going to get my tires checked for alignment soon to see if thats it, but do any of you guys have any solution??
jeeprookie15 is offline
post #2 of 23 Old 01-03-2012, 08:54 PM
Irongrave
are you running any sort of SYE or transfer case drop. my guess is your drive shaft angles suck and need to be addressed. with shims and an SYE
Current
2002 WJ 2wd DD
Irongrave is offline
post #3 of 23 Old 01-03-2012, 08:57 PM
dillonjm
2013 WK
Where was the vibration, steering wheel? Seat of the pants?
First step is to narrow it down to driveline or steering/wheel balance.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 23 Old 01-03-2012, 09:03 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
oh sorry i meant to say transfer case drop not driveshaft drop, and im running a stock driveshaft. I couldnt really tell where the vibration was directly coming from, but the WHOLE thing was shaking pretty badly. Im pretty sure people i drive by can hear it lol. Also, could it be that i put something on wrong on the lift kit or something isnt tight enough??
post #5 of 23 Old 01-03-2012, 09:12 PM
dillonjm
2013 WK
Just to rule out the possible obvious. Did you have the tires balanced? Check the lug nuts to make sure they are tight.
I'd run through and check the suspension bolts also. U-bolts should be 80ish, shackles anywhere from 45-70 depending on which school of thought you buy into regarding shackle bolt tightness.
Not sure if you opted to keep the track and sway bars or not, you can check those, but if the leaf springs' bolts are torqued correctly you can remove both with no issue.
The whole Jeep vibration leads me to believe its suspension/steering/tire balance related. Were it driveline it should just feel like a rythmic vibration in the butt (so to speak).
dillonjm is offline
post #6 of 23 Old 01-03-2012, 09:18 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
I just got the tires mounted and balanced. It came with new sway bar links and a track bar relocation bracket. Thanks for the torque specs on the leaf spring and shackles because i didnt know exactly how tight they were supposed to be. I just tightened them down with an air wrench. Any new thoughts or you still think its suspension/steering/tire balance??
post #7 of 23 Old 01-04-2012, 05:13 AM
bogleparsons
The kit came with a transfer case drop. Use it.
Your angles are probably off, can you take some pictures of the drives haft angles and post?
You may also need shims under your leafs if the TC drop doesn't alleviate the vibrations.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #8 of 23 Old 01-04-2012, 05:18 AM Thread Starter
jeeprookie15
1987 YJ Wrangler
I did use it!
post #9 of 23 Old 01-04-2012, 06:09 AM
jbeebe
so do you feel the vibrations in your steering wheel or the pedal? i understand you said the whole thing was shaking, but does the steering wheel shake back and forth too?
did you use shims in the rear?
jbeebe is offline
post #10 of 23 Old 01-04-2012, 06:40 AM
19renegade91
Driveshaft is reverse maybe like upaide diwn...mine was all I did was change unis and flip it over . Or flip the slip yoke either way it was installed wrong
19renegade91 is offline
post #11 of 23 Old 01-04-2012, 06:42 AM
19renegade91
Even if u marked it it could have been installe.d wrong before just try flipping it
post #12 of 23 Old 01-04-2012, 06:44 AM
danlee
1987 YJ Wrangler
Go to harbor freight and purchase this
http://www.harborfreight.com/dial-ga...der-34214.html
Check and make sure your drive line is around 22 degrees, this is ideal for you rear drive line
I didn't vote for him! Did You?
danlee is offline
post #13 of 23 Old 01-04-2012, 03:36 PM
meSiLlY
My front drive shaft caused vibrations when I jumped on the highway. Around that same speed too. Make sure to check, not only the ujoints, but the slip joint on the front shaft. The rear shaft can have some play and you really won't notice it. If the front shaft has any play, in the slip, at all (since it is longer)... you will know it!
Don't ask how I know...
meSiLlY is offline
post #14 of 23 Old 01-04-2012, 03:52 PM
hfa8592
I have a problem with my '93 I think as well, but it doesn't happen until I'm up to about 65. I have since replaced the rear springs and all four shocks, replaced the tie rod (& ends) along with the steering stabilizer, had an alignment and had the tires balanced. I have also replaced the ujoints on the rear drive shaft. The vibration is the same with or without the front & rear track bars. Doesn't make any kind of sound like that though. I can't figure it out.
Scott
'93 YJ, 4" spring lift, 4.0 I6, NV4500, Atlas II, SYE, Currie/Ford 9" rear axle, ARBs front & rear, Kilby OBA, 33" Wrangler MTRs, custom cage, custom bumpers.
hfa8592 is offline
post #15 of 23 Old 01-04-2012, 06:02 PM
jplks2play
did you tighten shackles before putting the weight of the jeep on them?
jplks2play is offline
vibration , YJ
vibrations ramil89 TJ Wrangler Technical Forum 7 01-12-2010 10:59 AM
Vibrations between 45-50 MPH doubleup TJ Wrangler Technical Forum 3 10-07-2009 11:48 AM
vibrations westmichjeeper TJ Wrangler Technical Forum 6 05-13-2006 08:09 AM
bad vibrations mikemac4 YJ Wrangler Technical Forum 9 12-09-2005 07:07 PM
Vibrations??? dompaz YJ Wrangler Technical Forum 3 11-07-2005 05:42 PM
