bad wandering - JeepForum.com
post #1 of 5 Old 04-23-2002, 09:37 PM Thread Starter
fsres1
bad wandering
I have a completely stock 88' Wrangler. I run 30" x 10" tires and have recently put in new bushing all around. I have had a wandering problem for the last 6 months. There is no uneven wear or loose parts that I can see. I have had it in twice in the past 2 months to have it checked out and "they" say everything is properly alligned. At low speeds everything feels tight and secure at about 25 and up the steering seems to wander heavily with the angle of the road. I am curious if this could be caused by old worn springs and if so how to tell if they need to be replace. Or if it may be in the shocks or steering gear box somewhere. When not moving the gear box feels tight and has no play. Any ideas.
fsres1 is offline
post #2 of 5 Old 04-23-2002, 09:56 PM
AllanAlxndr
I had a little bit of wander in my '90 so I replaced my steering stabilizer and it helped out quite a bit... Just something you might want to consider if it is the stock steering stabilizer...
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #3 of 5 Old 04-24-2002, 09:25 AM Thread Starter
fsres1
Are you talking about the shock or the stabilizer that goes from the axle to the frame?
fsres1 is offline
post #4 of 5 Old 04-25-2002, 02:40 PM
4wheeler4CJ
4wheeler4CJ's Avatar
If there is alot of steering play, it is likely to be your box. Could need a simple adjustment (tightens up the play).
4wheeler4CJ is offline
post #5 of 5 Old 04-25-2002, 02:43 PM
AllanAlxndr
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by fsres1:
<strong>Are you talking about the shock or the stabilizer that goes from the axle to the frame?</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I was talking about stabilizer, that goes on the rod between the two front wheels...
Allan
*'90 Wrangler*
*4 Banger*
Member of
wandering all over the road armada505 TJ Wrangler Technical Forum 19 07-13-2012 05:42 PM
wandering..tried everything..I think? KhakiTJ03 TJ Wrangler Technical Forum 19 05-11-2007 09:14 AM
Are you wandering? Shorty TJ Wrangler Technical Forum 9 04-15-2007 06:51 AM
I'm Wandering? 1BadJeepX06 TJ Wrangler Technical Forum 1 03-07-2006 01:20 AM
Wandering Fropleyqk TJ Wrangler Technical Forum 4 07-12-2005 10:01 AM
