Okay it only vibrate durring acceleration , When I let off the gas the vibration stops , It doen't matter what speed or what rpm . Only when accelerating I noticed that I have a worn motor mount as well . I was just wondering if its the cat , the motor mount , or driveshaft. the vibration is more like a violent shake any thought or sugestions ?:brickwall
If you know have a worn motor mount I'd start there and see where that goes. Your profile says you haven't lifted your jeep so I doubt its the driveshaft, unless those shackles are REALLY big.
My motor mount was shot and it was giving me a pretty good shuddering when I was accelerating and After I replaced mine the problem went away. If you know its bad should replace it regardless as it may be compounding other problems you have.They are only 18 bucks apiece at autozone if you haven't got a lot of money or you can go for a better aftermarket set. Good luck
Rick
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
