Bad vibration and sounds while in gear - Page 2 - JeepForum.com
post #16 of 33 Old 05-03-2013, 05:38 PM Thread Starter
ekrause72
Ya I'm really not sure exactly what a sye does I know that I have a t case drop with my skid plate spacers.... I think I just broke a bearing
ekrause72 is offline
post #17 of 33 Old 05-04-2013, 12:39 AM
JeepingJustin
Sye gives you better drive line angles so you don't eat up u-joints and gets rid of unwanted vibrations. I think most people recommend one if your running a lift bigger than 2.5 inch.
JeepingJustin is offline
post #18 of 33 Old 05-05-2013, 12:51 AM
jschilling
do you think that is what the problem might be then? That we need an SYE
jschilling is offline
post #19 of 33 Old 05-05-2013, 05:06 PM Thread Starter
ekrause72
I do feel that the sye would have prevented my problem but now I know I broke a bearing some where I can hear and feel it...my mech friend said drive it till it breaks
post #20 of 33 Old 05-05-2013, 09:55 PM
jkilmer83
1983 CJ7
If you do that it will cost you way more $$$$$$ then fixing it
1987 yj w/(new)258 .060 over comp cam mc 2150 carb
1989 yj sold
1983 cj7 w/258 t5 dana 300 45k original
mc2100 carb
You just can't fix stupid!!!
jkilmer83 is offline
post #21 of 33 Old 05-05-2013, 11:20 PM
JeepingJustin
I would find out what's broke instead of letting it go. Cause it will cost you more in the long run.
post #22 of 33 Old 05-06-2013, 01:07 AM
LowBudget87YJ
1987 YJ Wrangler
A SYE does not improve drive line angles. What it does do is replace your slip yoke with a fixed one on a shorter more sturdy output shaft and enables you to run a dual CV driveshaft which will eliminate drive line problems as far as angles from lifts. Do some research on them; theres several how to's in the sticky section on the YJ forum. Also most if not all SYE kits remove some of the inner bearings from the output shaft; so if indeed you have a bad bearing you could be killing two birds with one stone. Also please try to refrain from using text talk on here, it helps older people like me to understand what your talking about when you speak english. If you have further issues drop me a PM and ill try to help yall out as much as possible.
LowBudget87YJ is offline
post #23 of 33 Old 05-06-2013, 01:11 AM
LowBudget87YJ
1987 YJ Wrangler
Also you might wont to check your pinion bearing for excess play. Since you are still running a slip yoke drive shaft with a lift, it could of put excess wear on a already worn part.
post #24 of 33 Old 05-08-2013, 03:16 PM Thread Starter
ekrause72
So what would be the easiest way to check the pinion bearing ?
post #25 of 33 Old 05-08-2013, 03:34 PM
LowBudget87YJ
1987 YJ Wrangler
Pretty basic just drop your drive shaft grab a hold of the dang thing an see if you can wiggle it side to side or up an down. Also you can drop your drive shaft, jack up your rearend, and put it on jack stands and have a friend spin the tires while your listening for grinding. Im going to guess most of your vibration problems are from not having a SYE an CV drive shaft. I had some pretty bad vibration as well with my lift and tires ( 4inch lift, on 32s ). Cant say for sure if my pinion bearing was part of that problem cause I serviced the entire rearend when I did mine. IF you do plan on installing your SYE yourself I can not stress enough how much a good QUALITY pair of snap ring pliers are important.
post #26 of 33 Old 05-08-2013, 03:44 PM Thread Starter
ekrause72
I did todo the lift on this jeep but it seemed to be done very well....I have had almost no drive line vibrations until recently when I broke something. The noises have now started to come and go and are now happening when it's not in gear so I fear it may be a little to late. But next week I'm going to fix it starting on Monday so after I pull it apart I will take pics and prob ask for more advice . Thank you for all of your help bc I'm no mechanic
post #27 of 33 Old 05-08-2013, 03:45 PM Thread Starter
ekrause72
Edit : I didn't do the lift.
post #28 of 33 Old 05-08-2013, 07:10 PM
LowBudget87YJ
1987 YJ Wrangler
quick question does it stop grinding if you go around say a right or left turn if so which turn? cause the grinding could be a bad wheel bearing as well. If you hear the grinding and you make a right turn and it stops then it would be your driver side wheel bearing. If you make a left turn and it stops it going to be passenger side.
post #29 of 33 Old 05-08-2013, 07:54 PM
jschilling
Could that happen if I haven't gotten them aligned yet? Cause I got new tires after at the same time as I got my lift and that's when it started.
post #30 of 33 Old 05-08-2013, 08:15 PM
LowBudget87YJ
1987 YJ Wrangler
no alignment wouldnt have anything to do with it. but the added stress of larger tires on an already worn part would
