-   -   Bad vibration and sounds while in gear (http://www.jeepforum.com/forum/f12/bad-vibration-sounds-while-gear-1516956/)
ekrause72 04-30-2013 06:24 PM
Hey guys I own a 91 yj 5 speed inline 6 160000 mikes on it and I just replaces the main u joint on the rear drive shaft about a week ago. It was running great for a week. Then one day I ran over a bump in the street and immediately noticed I broke something. I have gone over the u joints again and they are in great shape. I am getting bad vibrations that shake the entire jeep during the middle of first and second gear.
ekrause72 04-30-2013 06:27 PM
I hear sometimes metal grinding noises or squeaks that come during first and second gear. This jeep is running 4 inch lift on 33 x 12.50 x 15's the jeep is still running and driving with these problems I was thinking I may have broken a Trans mount but I have no idea where to begin on this one. Please help I'm sure this is going to involve dropping my ax15 but I sure hope not
bentvalves 04-30-2013 06:52 PM
Is there a chance when the suspension compressed that it ran out of yoke and bottomed out into the transfer case damaging it?
ROTTEN 04-30-2013 09:47 PM
Take a pic of your driveline angle and post it
Trans mount is not hard to change
Get a pic
ekrause72 04-30-2013 10:55 PM
1 Attachment(s)
Here it is I dunno where the Trans mounts actually are
ekrause72 05-01-2013 08:12 AM
N e one have n e thoughts ? Def going to need some help with this one
ROTTEN 05-01-2013 08:31 AM
Do you have the skid plate dropped an inch? Im no expert but it might be that the drive shaft is binding and chewinv up u joints
The trans mount is below the trans and bolts into the skid. Take a pry bar and pry up on the trans
ekrause72 05-01-2013 10:19 AM
So guess the bad news is that the Trans mounts are not broken .....:( .... When I decelerate and remain in gear I can hear the play in the drive line from whatever I broke .....this leads me to believe that I damaged the transfer case....because there doesn't seem to be any problems with the clutch or Trans through any gears.....just the vibration that doesn't always happen....it happens prob 8 out of 10 times that I come off of the clutch....what can I do to diagnose the transfer case without actually just pulling it out .?? Btw thx you for your input
[QUOTE="ekrause72"]So guess the bad news is that the Trans mounts are not broken .....:( .... When I decelerate and remain in gear I can hear the play in the drive line from whatever I broke .....this leads me to believe that I damaged the transfer case....because there doesn't seem to be any problems with the clutch or Trans through any gears.....just the vibration that doesn't always happen....it happens prob 8 out of 10 times that I come off of the clutch....what can I do to diagnose the transfer case without actually just pulling it out .?? Btw thx you for your input also yes I do have the skid plate dropped a inch
ekrause72 05-01-2013 10:20 AM
Also I do have the 1 inch drop on the skid plate .
ekrause72 05-02-2013 05:55 AM
Anyone have n e thoughts ?
jschilling 05-02-2013 12:41 PM
I just got a 3" lift and 33" tires put on mine and its doing the exact same thing so someone please help haha I don't know if its something broken or just some noise because everything is having to work harder with the 33" tires.
ekrause72 05-02-2013 07:35 PM
Nobody likes us lol
ROTTEN 05-02-2013 07:48 PM
I do! I just dont have enough knowledge of this to help you out
jschilling 05-03-2013 10:24 AM
I know that if you get a lift sometimes people get SYE's or a transfer case drop. could it deal with us needing one of those?
The time now is 05:43 AM.
